Author Topic: CDI Wiring problem... Yamaha  (Read 1662 times)
Offline davidstipek
  • Past... Present and Future.... are Participles!
« on: February 21, 2013, 05:53:40 AM »
Replaced harness (Wiring) and bought new CDI to complete wiring issues.
In beginning I had fabricated harness as I felt needed. Now that bike is done to clean up the scrambled mess I had made I bought a replacement Yamaha 80-111 harness. Also because CDI had areas where not sealed right and when it rained sometime engine died, I replaced it also.
Okay new harness is in Bike, everything connected perfectly... except one wire!
White/Blue stripe at Mag/Engine. Even new CDI has White/Blue Stripe okay. It seems this is the only two connections for this wire
Mag Wiring:
Green (White stripe@ Harness)
Green/Red stripe(Green/White stripe @ Harness)
White/Red stripe
Black
Black/Red stripe
Yellow (Yellow/Red stripe @ Harness)
Harness Wiring
White
Yellow/Red stripe
Green/White stripe
White/Red stripe
White/Blue stripe ???? This is wire in question??
System is 12V. I have checked four other Mag. Plate assemblies (two 6V and two 12V) and they are same as mine. Only difference was Early 12V as it still had:
Green instead of white
Green/Red stripe instead of white stripe
Yellow instead of Yellow/Red stripe
None of the 5 Mag. Assemblies (all are complete) have a white/blue stripe!
All the 12V assemblies I have also have in harness;
Lite/Blue - Neutral Switch Light
Blue/White stripe - Top Gear Light
I don't want to even try to fire bike up as this wire is only between CDI Box and Apparently Magneto Assembly.
Can anyone help me find a home for this wire??
David
 When I Gaze at the Beauty walking around Me... What Participle of Me is Where....?
Re: CDI Wiring problem... Yamaha
« Reply #1 on: February 21, 2013, 06:48:40 AM »
Never did see the year or model of Yamaha   :-\
Offline davidstipek
« Reply #2 on: February 24, 2013, 07:38:21 AM »
Original CDI and wiring is a 1984-86 Yamaha Y80 Belle.
Replacement Harness and CDI match our 1996 Yamaha 111D Mate Super
I believe I have found the answer as the replacement parts use the white/blue stripe wire as a CDI coil ground at stator. Original had everything using blak wire as ground. bike fires up with white /blue at coil with otherside white/red or also ataching black wire at stator to the white/blue have same spark either way! but with new wiring and CDI I have much hotter spark! Then when bike was new years ago!
David
