Author Topic: 1974 cb550; Fixin' this baby up!  (Read 32799 times)
Re: 1974 cb550; Fixin' this baby up!
« Reply #125 on: June 04, 2015, 04:09:18 PM »
I'll have to check.  I can't quite remember.  I'm positive it was the stock length.
Could be. Once you have it in your mind, you question whether it looks longer.
Yeah, they seem longer, but I like it! The Hagons I was going to order were a hair longer than stock at 13.2" I believe. Do remember yours, Don?
I'll have to measure them later.
Offline dmonday
« Reply #126 on: June 20, 2015, 06:32:29 PM »
New pics from today
Looking for a cool, one of a kind motorcycle desk piece?
http://advrider.com/forums/showthread.php?t=861422
« Reply #127 on: June 21, 2015, 10:36:50 PM »
Nice new pics and nice new markers/signals.
« Reply #128 on: June 22, 2015, 01:27:23 PM »
Nice job on the bike. Don't show Sam, he hates black wheels...  ;)
David
Offline dmonday
« Reply #129 on: June 29, 2015, 10:32:31 AM »
Update on the bike...
Had an issue with the oil indicator light flickering at low RPM.  I started noticing after I'd ride it for a little while.  Also after changing the clutch it was virtually impossible to get into neutral at a stop, but if I turned the bike off to take the load off the clutch it would easily pop into neutral.  After doing research I changed oil from the Rotella to the Castrol motorcycle oil.  Didn't solve either issue, although I think it shifts a little better.  I changed the oil pressure sender unit and that fixed the oil pressure light.
My wife and I were on a ride and I noticed I had more play in the clutch handle than I had when we started.  I ordered a new clutch cable b/c the one I had, had stretched.  I can get Neutral easier while still moving now(11mph works best), but from a stop it's pretty much impossible.  I also changed to a new chain and sprockets.  Looks like that is something that will need replaced about every 2 years on this bike.  Other than that, the bike is great and a joy to ride!
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« Reply #130 on: November 12, 2015, 06:08:38 AM »
Do you have the exact model number of the MotoGP Werks Exhaust System?  I can not see to find a picture of the system anywhere on their website.
Thanks in advance,
Gary
Offline PGF550F
« Reply #131 on: November 12, 2015, 03:49:36 PM »
Man your whole bike looks soo clean. How do you like the trail tech multiguage? I can't quite tell from the pictures, what did you use for your speedo and tach pickup? I can see you kept the stock speedo drive on the front wheel and have a single cable running down toward the axle. I'm curious about what you did for the pickup.
