Author Topic: Restoring Neutral Light on 400F SS  (Read 752 times)
Offline Desdolph
« on: February 22, 2013, 05:29:12 PM »
 :-\ I took my 400F to have a new start/kill switch wired in since it was too cold in my carport to do the work myself. I'm glad I did. When they got in there they found a lot of cobbled together wiring. They traced and restored most of the connections  as per the wiring diagram, but that eliminated the neutral light, although it had been working before. They never went into the case where the neutral light is situated.
The switch and wiring at the clutch to prevent starting in gear is long gone. I can live having to remember to pull in the clutch or roll the bike to be sure it's in neutral, but life would be easier  with a working neutral light. What do I need to do to make get the neutral light to turn on when the bike is in neutral, even though I don't have the clutch end of the safety switch? wiring?
Offline bjbuchanan
Re: Restoring Neutral Light on 400F SS
« Reply #1 on: February 22, 2013, 06:31:24 PM »
Neutral gets power from a black wire in the bucket area. grounds at the case. The switch in the case is what actually grounds it and sends the juice to the light. Either now power to it, i.e. no black plugged in(likely bc it could be disturbed or missed doing that kind of work) or less likely it somehow is out of the blue having trouble grounding. Does your neutral switch leak?
Offline phil71
« Reply #2 on: February 22, 2013, 10:34:27 PM »
Sounds like they just knocked a wire loose. It's light green with a red and , as stated before black is the (+).
trace them back , and i'm sure you'll find one isn't connected.
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #3 on: February 23, 2013, 11:31:42 AM »
or the bulb has blown.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline phil71
« Reply #4 on: February 23, 2013, 08:01:30 PM »
um yeah... he's right, check the bulb first.
Offline Desdolph
« Reply #5 on: March 17, 2013, 06:52:07 PM »
Been away for a while. Thanks all. Will follow up on your leads - NPI  ;)
