Just recently put some clubmans on my 77' CB750 ... I went to put the throttle back on and and it was sticking pretty bad. I figured it was because the cable was binding so I rerouted the push/pull cables. This helped a little but it's still not where it needs to be. The clutch cable will probably need to be rerouted as well.
Is there anything else I should check for? New cables? Re-lube the cables?
