Author Topic: How far to cut rear of frame for cafe hoop  (Read 2223 times)
Offline MOTOJESUS
  • MotoJesus
    • www.essink.biz
« on: February 25, 2013, 06:19:54 AM »
How far back to i need to cut to install the frame hoop, i dont want to go too far. Does anyone have pics of their process of cutting it back.... Just dont want to overdo it for obvious reasons. Thanks in advance for the help...
1976 cb550f, 2006 Suzuki ltr-450 sport quad.
Offline MOTOJESUS
  • MotoJesus
    • www.essink.biz
Re: How far to cut rear of frame for cafe hoop
« Reply #1 on: February 25, 2013, 06:20:11 AM »
1976 cb550
Offline wenger828
« Reply #2 on: February 25, 2013, 06:39:52 AM »
just finished mine last night on my 78' cb750f.. probably different but i cut mine all the way to the shock mounts and then cut the hoop to length to fit my thruxston seat.. i'll post up pics when its done uploading
78' cb750F SS first cafe build! check it out here
http://forums.sohc4.net/index.php?topic=116603.0
Offline lucky
« Reply #3 on: February 25, 2013, 06:41:55 AM »
Carefully remove the rear shocks (jack under the bike) and let the rear of the bike down.
Make sure the hoop extends past the rear tire when it is in that position.
OR...Put the bike on the centerstand and remove the rear shocks then lift up the swing arm and make sure the hoop extends past the rear tire.
Offline Cqyqte
« Reply #4 on: February 25, 2013, 06:50:01 AM »
It really depends on the structure of the frame and then the overall lines that you want to achieve.  I have done a hoop on a '75 CB750 and '71 CB450, but I only have pics of the 450 during construction.
Too short and the lines don't flow, too long and it looks like an add-on and bulky.  Structurally you need to keep the frame integrity and design intact.  You also need to think about rear wheel travel, if the rear wheel on full deflection tucks into the frame rails then the hoop must be outside the line of that travel or be arched up to accommodate.  Hope that helps... :D
Offline wenger828
« Reply #5 on: February 25, 2013, 08:50:20 AM »
this is where i did mine..
Offline sethdhawkins
« Reply #6 on: February 25, 2013, 01:22:03 PM »
On the 750's, they have a little boxed portion that's part of the shock mount, if you cut to that, you have to either fill with weld, or with bondo prior to paint. I did both. You could put two fat-asses on my bike, with 12-1/2" shocks, and there's no way that tire would ever touch the hoop (it's also upswept a lil')...even if it were shorter. It's purely an aesthetic preference.
« Last Edit: February 25, 2013, 01:23:55 PM by sethdhawkins »
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
« Reply #7 on: February 25, 2013, 01:26:05 PM »
Not a great photo, but there you go.
1972-ish CB750K
1974 CB450
1974 CB360
