Author Topic: '76 550 - have extra pieces after carb clean?  (Read 1533 times)
Offline 76cb550k
« on: February 26, 2013, 09:21:25 PM »
I'm a new owner and new to bikes, but had to clean my CB550's carbs.  I noticed I have these pieces lying around.  Any idea where they go?  I checked everything and all the valve and chokes open smoothly.  Thanks  :'(
Offline harisuluv
Re: '76 550 - have extra pieces after carb clean?
« Reply #1 on: February 26, 2013, 09:56:25 PM »
From left to right:
1.  One of eight springs for the lifters (2 per carb)
2. Dark but looks like pin between #2 and #3 that throttle return spring attaches to.
3. Goes with #1 in contact with ball joint from lifter arm or bracket/plate
4. My guess would be slide washer, where slide attaches to lifter arm. Also check the 8 cap screws.
Offline 76cb550k
« Reply #2 on: February 26, 2013, 10:14:18 PM »
you're awesome - thank you so much.
also, nice work on the carb cleaning service!
Offline harisuluv
« Reply #3 on: February 26, 2013, 10:20:23 PM »
Thank you and your welcome.
Online Deltarider
  • I'm back
« Reply #4 on: February 27, 2013, 12:28:20 AM »
Another reason not to separate carbs unless absolute necessary. Personally I've never needed to separate them and have always done the maintanance with carbs on the rack.
CB500K2-ED Excel black
Offline 76cb550k
« Reply #5 on: March 03, 2013, 04:47:08 PM »
From left to right:
could you kindly tell me what the lifter spring is you're referring to? :) i found #4 and i'm not sure #2 is necessary, but im not sure what you're referring to for that as well.
do i absolutely need to put these back on? Haha  :-[
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #6 on: March 03, 2013, 04:49:28 PM »
Yes you do, otherwise they wouldn't be there in the first place.  ;)
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline SohRon
« Reply #7 on: March 04, 2013, 04:38:51 PM »
The parts you're picturing come from the synch adjusters - they're not listed individually on this fiche, but are included among the parts indicated by #29. Pull one of your intact adjusters apart and you'll see what I mean.
#2 appears to be the inlet valve, #4 is the float and pivot; def needed or your carbs will not work. The Honda engineers didn't spend a lot of time just making up parts to confuse people with; all of the parts are absolutely necessary for the bike to function!
If you're confused as to what parts go where, I'd be concerned about the level of your rebuild.   :o
« Last Edit: March 04, 2013, 04:49:18 PM by SohRon »
« Reply #8 on: March 04, 2013, 11:41:52 PM »
Having blown up your picture the spring and both black bits appear to be out of a sync adjuster, one black bit is the fixed seat for the ball and the other the sprung seat. If you look closely both have a curved indentation
The last bit is a spring washer and without it whatever it should be on will fall off
