Author Topic: Juha and Mike Rieck top-end  (Read 34175 times)
0 Members and 7 Guests are viewing this topic.
Offline Jim F
  • go baby go
« on: February 27, 2013, 10:54:41 am »
Yes its not a SOHC Honda but I just wanted to show what
you can do when you have Juha (one of the fastest GS1100 racers in Turku, Finland)
and a collaboration between Mike Rieck and Rick Stetson (Turbo fast guy with numerous championships)
This is a 2mm over Wisco kit with a Stage something (Mike please chime in for the details) Head
heavy springs with Ti retainers but not sure about how big the valves are
very nice porting with Cam Motion G4 cams
top end oiling system
and I have some RS36 flat slides on order to really make this a complete bike
so not only does Mr. Rieck do SOHC heads he is very good at other makes in including my GS750 in which he did an 850 head
with shim under buckets thats up at the dyno as I type this
enjoy
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Bill/BentON Racing
    • BentON Racing
Re: Juha and Mike Rieck top-end
« Reply #1 on: February 27, 2013, 11:05:51 am »
Nice brother! Let us see the results!  ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline voxonda
« Reply #2 on: February 27, 2013, 11:06:54 am »
Yep, Mike is the guy for all heads! ;D
« Reply #3 on: February 27, 2013, 11:07:12 am »
Jim, you dropped your pink lipstick in there  ;D
That's gonna be nice! Will you have before and after dyno numbers?
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #4 on: February 27, 2013, 12:00:03 pm »
How about the valve to piston clearances? Are they OK?
Those parts have traveled a lot... Looking good Jim!
Offline Leino
  • Not much of an
« Reply #5 on: February 27, 2013, 12:08:16 pm »
Valves are 28.5mm and 23mm, exhaust valves are stock.
« Reply #6 on: February 27, 2013, 12:19:33 pm »
Other type heads? Well sure.  ;D
Mike did a pair of RC51 heads for an old pal of mine that brought a smile to his face!
Offline Jim F
  • go baby go
« Reply #7 on: February 28, 2013, 06:25:35 am »
Well nothing is hitting any where and a fellow drag racer is coming over tonight to check
the cam timing to make sure we are still on the correct lob centers
Cant find the info about the centers but I think its in the 108 to 110 center
will make sure
Jim
Offline Jim F
  • go baby go
« Reply #8 on: February 28, 2013, 06:35:01 am »
was going to get the numbers on the stock motor but should be the same as a new one or a little more
Dyna ignition and coils, pods and pipe. carbs have a jet kit in them
going to get it up to the dyno as soon as I have it finished
Jim
Offline Jim F
  • go baby go
« Reply #9 on: February 28, 2013, 06:35:58 am »
Mike and I both have RC51s ..............Nope I am not going to do it
but I said that about the GS too so
Jim
« Reply #10 on: February 28, 2013, 08:18:34 am »
You're no fun Jim ;D Is that the head I did for the old Katana?? If so it is basically a Stage 2 head. Very, very streetable with good bottom end and a nice top end finish. It will work very well with the 36 RS's.
Offline Jim F
  • go baby go
« Reply #11 on: February 28, 2013, 09:21:12 am »
It might be Mike but you would have to ask Juha about what it went on
The port work is nice with heavy springs and Ti retainers and the valve guides have been
cut to the port wall as to not get in the way for in coming gasses (I guess)
Let me know if you do your heads on the RC51 and then maybe we can start another project
will call soon
Jim
Offline Leino
  • Not much of an
« Reply #12 on: February 28, 2013, 10:27:45 am »
Yes, it was ported for the '82 Katana my son will be racing this year.
Offline Leino
  • Not much of an
« Reply #13 on: February 28, 2013, 10:54:23 am »
Jesse's Katana will have pretty much the same setup as Jim's GS, 1166cc Wiseco's, similar Mike Rieck head, G4 cams, Dyna 2000 but I'll be using '86 GSX-R 750 carbs to calm the bike down a bit. Should be enough for a 15 year old kid anyway.
Offline Jim F
  • go baby go
« Reply #14 on: February 28, 2013, 11:11:05 am »
We can compare notes when I take it to the dyno on what the 36RS flat slides will do
Jim
Offline Leino
  • Not much of an
« Reply #15 on: February 28, 2013, 11:15:20 am »
Jim
Sounds like a plan! Remember, that stuff only has about 300 miles on them.
Offline Jim F
  • go baby go
« Reply #16 on: February 28, 2013, 03:30:39 pm »
Yeah everything had a light coat of carbon and it cleaned up nicely (Pistons, Combustion chambers)
So its time to get it on the dyno.........plenty of break in time for 300 miles
thanks again Juha
Jim
will keep you posted
Offline Leino
  • Not much of an
« Reply #17 on: March 01, 2013, 11:41:59 am »
Jim, did you measure the deck height?
Offline Jim F
  • go baby go
« Reply #18 on: March 01, 2013, 01:11:07 pm »
No But I am glad the head gasket put it back about .030
There wasnt much there
Got the cams timed last night (with in .1 degree of the recommended timing)
everything is ready
Just waiting for the carbs to get in.............
But........... I keep blowing the main fuse when I try to turn the engine over........................
everything turns on and all of the electrics work but when I turn the engine over just for a sec
it pops the fuse.................strange NO the valves are not hitting and putting a load on the engine....:)
Jim
« Reply #19 on: March 01, 2013, 03:55:19 pm »
everything is ready
Jim
.030 squish total Jim? Hard snapping fuses are usually a positive hitting ground. That's my experience. Or the solenoid is crap. Or the ground strap is crap. etc etc etc.
Offline BLUE71TURBO
« Reply #20 on: March 01, 2013, 03:58:40 pm »
 Yes, definitely have a hot wire or source grounding somewhere .   :o
Offline Jim F
  • go baby go
« Reply #21 on: March 02, 2013, 09:52:22 am »
everything is ready
Jim
Thanks Mike
I am in the shop and will start to look more closely
will call you this weekend
Jim
Offline Jim F
  • go baby go
« Reply #22 on: March 04, 2013, 08:32:34 am »
got the fuse problem traced to a bad rectifier.
ordered one today and should be in with the new carbs, mag cover gasket
Jim
Offline Leino
  • Not much of an
« Reply #23 on: March 04, 2013, 09:55:32 am »
OK Jim, good thing you found the problem.
Offline Jim F
  • go baby go
« Reply #24 on: March 04, 2013, 11:55:22 am »
should be up an running by the weekend and then get it to the dyno
Jim
