Author Topic: Juha and Mike Rieck top-end  (Read 36146 times)
Offline Jim F
  • go baby go
Re: Juha and Mike Rieck top-end
« Reply #125 on: October 07, 2013, 10:28:00 AM »
well the story continues as they found that the aftermarket regulator/rectifier is bad (Electrosport) ordered a new one
and a new OEM to make sure its not just the aftermarket one
will keep everyone posted
Jim
Jim....you want GOOD luck....not BAD luck. ;) I'll be honest.....the GS's were never known for stout charging systems to begin with. I have replaced quite a few stators and Reg/Rec units
and they think the RF might be coming from the bad R,R..............not sure but it has to be replaced
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #126 on: October 07, 2013, 10:36:04 AM »
I have removed a couple of charging systems...  ::)
Offline Jim F
  • go baby go
« Reply #127 on: November 03, 2013, 08:05:01 AM »
One of the Gs bikes got on the dyno yesterday and yes the cam timing was WAY off
This has a Mike Reick head (GS 850 head with mikes porting, under bucket shims and all of the good valve train stuff)
840 kit with cams and 32 mm flat slides.
stock, this motor makes 61HP and the last time we put it on the dyno it made a whopping 62 with this set up.
got the cam timing figured out (Its been so long sense I have worked on this bike that I forgot who did the cam timing)
and I dont know how too so I am not even going to try this. (Thanks David Fletcher for helping me)
Now it makes 81 with the carbs being very lean. going to change with mid range and the mains and get the carbs
back up and on the bike and back on the dyno. so far so good
well keep you posted
Jim
« Last Edit: November 03, 2013, 08:42:59 AM by Jim F »
« Reply #128 on: November 03, 2013, 12:20:01 PM »
Should find a few more HP with some extra fuel Jim.
Offline Jim F
  • go baby go
« Reply #129 on: November 03, 2013, 02:19:51 PM »
Brian seems to think about 5 more, but 23/25 Hp gain is not bad
with this set up
« Reply #130 on: November 04, 2013, 06:17:08 AM »
with this set up
I won't argue with you there Jim. ;D Amazing what cam timing can do (or undo). ;D ;D ;)
Offline Leino
  • Not much of an
« Reply #131 on: November 04, 2013, 01:42:22 PM »
with this set up
I have a GS 750 classic-roadrace bike in my shop, someone installed hi-po cams but didn't know how to do timing properly... not sure if I know how to do it properly but I think I have an idea, thanks to MRieck  ;)
Interesting to see what it's capable of before and after cam timing...
Offline Leino
  • Not much of an
« Reply #132 on: November 04, 2013, 02:07:07 PM »
Maybe it will be worse than stock after me  ;D
Offline Jim F
  • go baby go
« Reply #133 on: November 05, 2013, 06:12:53 PM »
it is possible Juha be-leave me. I set the intakes at 105 degrees and the exhausts at 107/108.
its a good place to start but this is just a street rider
Offline Big Jay
    • CBRzone
« Reply #134 on: November 11, 2013, 02:42:21 AM »
By the way, ECR Racing in Finland is building a FJ based supercharged funnybike...
If it is using stock crankshaft, it will break them.
Offline Leino
  • Not much of an
« Reply #135 on: November 11, 2013, 08:08:07 AM »
I'm sure they will break a lot of sh1t in a hurry and do that many, many wonderful times...
Offline Jim F
  • go baby go
« Reply #136 on: November 23, 2013, 05:33:17 PM »
up date
we are up to 86 HP. went 4 sizes up to 130s and now we have about 12.7 AF
mid range a bit rich now, but we are getting in the ball park
The 1100 should be up next week too
Jim
Offline Bill/BentON Racing
    • BentON Racing
« Reply #137 on: November 23, 2013, 06:06:13 PM »
K, good to hear from you. did you see next years back @ Valdosta? Almost where Samauto is!!! ;) ;D 87.07 haha! 8) Bill
BentON Racing Website
BentON Racing Facebook
  • Moderator
« Reply #138 on: November 24, 2013, 03:42:26 AM »
Did you get a torque reading Billy when you got the 87.07 ? I'll bet it's higher now.
Sam. ;)
« Reply #139 on: November 24, 2013, 06:25:55 AM »
up date
Jim
There you go Jim. ;) 62 to 86...funny what cam timing and jetting can do. I'd like to see the chart when you are done. Most of the people that complain about losing all their midrange torque for "explosive" top end with most aftermarket cams really don't know much about either of those subjects. ;D
« Last Edit: November 24, 2013, 08:18:57 AM by MRieck »
    • BentON Racing
« Reply #140 on: November 24, 2013, 06:47:38 AM »
Samauto threw down the gauntlet! ;D  Bill I'll check Sammy boy! 8)
Offline Jim F
  • go baby go
« Reply #141 on: November 24, 2013, 08:39:08 AM »
The funny thing about the top end mike is that at 10K RPM, the graft hasn't leveled off, its still climbing and making HP
The crank has been welded and balanced but 10K is a good stopping point.
I will post all of the read outs when its done,
Jim
« Last Edit: November 24, 2013, 08:42:20 AM by Jim F »
« Reply #142 on: November 24, 2013, 11:21:48 AM »
Jim
Those ports are pretty good size Jim. ;) ;D ;D
Offline Leino
  • Not much of an
« Reply #143 on: November 24, 2013, 12:06:01 PM »
86hp at the rearwheel?
Offline Leino
  • Not much of an
« Reply #144 on: November 24, 2013, 12:34:23 PM »
Really looking forward to the 1100 or should I say 1135 dyno results ;)
« Reply #145 on: November 24, 2013, 01:55:42 PM »
Yes. I think it could pinch 90 with a few more RPM's.....like 500 or maybe 750. $hit....the crank is welded!
« Last Edit: November 24, 2013, 01:59:59 PM by MRieck »
    • BentON Racing
« Reply #146 on: November 24, 2013, 04:28:14 PM »
Yeh Jim, c'mon man, twist that puppy til the power falls off ! Mikes porting on a CB 750 will make power way past the 9500 most are done by! Now didn't you own a turbo bike?lol! Bill
Offline Jim F
  • go baby go
« Reply #147 on: November 25, 2013, 07:06:09 AM »
Offline Jim F
  • go baby go
« Reply #148 on: November 25, 2013, 07:07:28 AM »
[/quote
but there's not a rev limiter on it either
and yes the turbo bike should be up there in the next couple of weeks
Offline Leino
  • Not much of an
« Reply #149 on: December 13, 2013, 12:25:48 PM »
Almost three weeks have gone, what's up Jim? ;)
