Author Topic: Juha and Mike Rieck top-end  (Read 38562 times)
Offline Leino
  • Not much of an
  • in drag racing since 2005
Re: Juha and Mike Rieck top-end
« Reply #150 on: December 13, 2013, 12:27:53 PM »
By the way Jim, guys are absolutely right about the limiter, welded crank... rev it  8)
Just make sure your starter clutch is in good shape...
Offline Jim F
  • go baby go
« Reply #151 on: December 13, 2013, 01:44:45 PM »
up date on the 1100.................need to change out the plug wires..........found out that they were causing the RF
signal that was messing up the dyno. We where looking to hard into the charging system and other components
that might be or could be going bad. Although the Stator had lost a phase, we changed that out but still too much interferences
So next week we will get the 1100 back on the  dyno and try again.
The GS 840 had new needles put in (The ends of 2 were bent) and one pilot jet was blocked and its ready also
I will get Brian to up the RPM to 10,500 or 11,000 to see if we can get 90 HP. that would be a very strong GS
also that turbo bike should be finished this weekend and its going to the dyno too
that should be fun
will keep all posted
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Leino
  • Not much of an
« Reply #152 on: December 13, 2013, 02:40:28 PM »
Thanks Jim, really looking forward to seeing your results, still working on the GS 750 racebike, no dynoresults to post.
« Reply #153 on: December 13, 2013, 07:33:06 PM »
10,500 is enough Jim.
Offline Jim F
  • go baby go
« Reply #154 on: December 14, 2013, 12:53:53 PM »
10K is where we are now but I don't think that another 500 RPM,s is going to hit 90 but who knows...........
its going to be a fun back road burner regardless
will call soon Mike and Merry Christmas to all
Jim
Offline Leino
  • Not much of an
« Reply #155 on: January 10, 2014, 11:45:31 AM »
What's up Jim?
Offline Jim F
  • go baby go
« Reply #156 on: January 10, 2014, 12:07:13 PM »
up date
we have a blown head gasket on the black bike (Gs 750)
called cometic about a replacement and they can make a MLS gasket for it
the 1100 is waiting on the new plug wires and plugs (Resistor type)
Going to get the 750 back to my shop, get the head pulled off and check everything out.
going to try and replace the stock cylinder studs with APE Units and bolts
still waiting to finish the turbo bike and get it back to my shop to program the MSC box for backing the timing down when the boost kicks in
Patients, .....................whats that..............lol
Jim
Offline Leino
  • Not much of an
« Reply #157 on: January 10, 2014, 12:45:51 PM »
Ok Jim, I spent the last 6 weeks of the year 2013 moving stuff and bikes to one location from three different locations so I'm behind on my schedule.
Hope to have the 1500cc engine coming along shortly, Mike has the head ready and Sam took care of the pistons and cylinders a while back... 200+ at the wheel?
  • Moderator
« Reply #158 on: January 10, 2014, 12:52:57 PM »
Is that all ? hahahaha
Offline Leino
  • Not much of an
« Reply #159 on: January 10, 2014, 12:59:26 PM »
200+ reaches all the way to 300 Sam  ;)
Offline Leino
  • Not much of an
« Reply #160 on: January 10, 2014, 02:23:21 PM »
Jim, here's the bike your top-end came from ;)
Offline Jim F
  • go baby go
« Reply #161 on: January 11, 2014, 09:53:35 AM »
Nice and ill bet I can make my bike do that also.........................NOT...............its too nice to mess up the rear tire (or tyre)
« Last Edit: January 11, 2014, 09:56:28 AM by Jim F »
Offline Leino
  • Not much of an
« Reply #162 on: January 11, 2014, 11:13:12 AM »
Oh well, my son likes to do his burnouts like that  ;)
Offline Jim F
  • go baby go
« Reply #163 on: January 24, 2014, 11:39:39 AM »
finally an update on the 1100
some jetting changes needed but we are up to 102HP
as soon as we make the changes then I will post the final results
Jim
Offline Leino
  • Not much of an
« Reply #164 on: January 24, 2014, 11:55:27 AM »
Jim
Thanks Jim, sounds like you are missing about 40HP?  ::)
 Juha
« Reply #165 on: January 24, 2014, 03:20:50 PM »
Jim
 Juha
In period 5 racing down under they are getting 180 BHP out of those old Suzuki 1100's.... 8) ;)
Offline Leino
  • Not much of an
« Reply #166 on: January 25, 2014, 12:02:34 AM »
Jim
 Juha
Yep, not a problem for a purpose built racebike but with the setup Jim has he should be around 140-145HP.
What is the displacement limit and are they running on methanol?
« Last Edit: January 25, 2014, 08:05:12 AM by Leino »
« Reply #167 on: January 25, 2014, 02:56:01 PM »
Jim
 Juha
Displacement limit is 1300cc and they run on pump gas as far as i know, period 5 and 6 were the only 2 race categories running on pump gas last time i checked, all other classes ran Methanol, that may have changed, i don't know...I just emailed a friend that builds classic race bikes, i'll let you know what he says ... ;) ....
« Reply #168 on: January 25, 2014, 05:25:09 PM »
Jim and I spoke today....I think things will get straightened out in the near future. ;) Don't worry.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #169 on: January 26, 2014, 05:11:44 AM »
Damn Mike, you told him to put all 4 plug wires on! ;D Only you can send 40 hp over the phone! 8) Jim, hang in there, you'll get it and then when you twist the throttle, it will all be worth it. ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline Leino
  • Not much of an
« Reply #170 on: January 26, 2014, 08:21:17 AM »
I've seen Mike sending 190HP by mail, so 40HP by phone isn't even a challenge  ;D
Offline Leino
  • Not much of an
« Reply #171 on: February 14, 2014, 01:16:19 PM »
What's up Jim?
Offline Jim F
  • go baby go
« Reply #172 on: February 14, 2014, 01:35:36 PM »
well all of the bikes are here in my shop so here it goes
The 840 GS has a blown head gasket (Sucking air threw the cam tunnel) and the top end is apart
waiting on the rectangular O ring that goes around the cam tunnel to come in, base gasket, head gasket,
heavy duty studs and nuts are in. (Thanks Mike R) for getting the studs and nuts
The Turbo bike is ready for the dyno also. Just programed the MSD Box to start the retard when boost kicks in.
need to also get the GS1100 down here to re time the cams and check everything one more time........... Not enough
room in the shop for all 3.
Brian at Livingood motorsports is busy getting the R6 motors ready for team Yamaha so he wont be doing anything
on my bikes until after Daytona as he will also have to tune the R6 motors
at least we are making some progress (Although a bit slow) but we are heading in the right direction..................
Jim
« Reply #173 on: February 14, 2014, 01:49:49 PM »
That's OK Jim, I don't have anything I can ride either  ;) ;D
Gotta sign over the title on the Harley today so the insurance company will pay me. Never had to do ANY work on it and didn't want to start now. I enjoy following all these other threads more but I'm looking forward to all your progress after seeing the engine pieces on your work bench.
Offline bear
  • Leeton in Australia
« Reply #174 on: February 15, 2014, 02:22:54 AM »
Jim
 Juha
OY!...............I"m your mate that builds classic race bikes, ;D and yes your right P5 and 6 run petrol.
Brian
