The SOHC/4 World Tour is in under way.
0 Members and 7 Guests are viewing this topic.
Quote from: Jim F on May 24, 2014, 07:38:53 AMThe cams have been retimed ( 105 for the intake and 107 for the exhaust)Installed a pingel fuel valve to keep the flat slidesFrom starving on top endSo both the 840 and the 1100 are ready to go backTo the dyno next weekWill keep you postedJimI hope you measured valve to piston clearances carefully, I had problems with the same setup when trying to go under 108 on the intake side. Juha
Quote from: Leino on May 24, 2014, 11:50:48 AMQuote from: Jim F on May 24, 2014, 07:38:53 AMThe cams have been retimed ( 105 for the intake and 107 for the exhaust)Installed a pingel fuel valve to keep the flat slidesFrom starving on top endSo both the 840 and the 1100 are ready to go backTo the dyno next weekWill keep you postedJimI hope you measured valve to piston clearances carefully, I had problems with the same setup when trying to go under 108 on the intake side. JuhaThanks for the info Juhawe did bump the valves but that was only when we went too far the first time (I think we got to 90 or 95 degrees on the intake side)and when we went back to 108 109 we where fine)I can check that over the weekend before we go to the dynothanks for reminding me Jim
hope that power will be much more on track now that we have the fueling issue fixedand a more conservative cam timing for some mid range gruntwill seeI`ll call you this weekend mike if your going to be inJim
