Author Topic: Removing valve guides  (Read 657 times)
« on: February 28, 2013, 05:00:19 AM »
I did my homework by searching the forum, looks like:
-  a special drift is needed - I will make one, no problem
-  heat the head to 300F is recommended
Now how about the guide clip?  CMSNL schema shows them and I actually verified they are there  ;D  Do I need to take them out first or will they go with the guide?
Re: Removing valve guides
« Reply #1 on: February 28, 2013, 06:58:42 AM »
They are attached to the guide and move with it. You have to bead blast the ports to remove carbon.
« Reply #2 on: February 28, 2013, 07:48:23 AM »
Thank you.
Offline crazypj
  • I'm brill, me
« Reply #3 on: February 28, 2013, 08:17:23 AM »
Be very careful re-fitting, the clip is a guide not a stop.
If you go too deep it will compress on guide and can cause it to crack while running (after a few/several heat cycles)
 I've repaired several on various singles although never had issue with inline 4
