Author Topic: 1997 Dodge Dakota 4x4 OBD code p0740 torque converter solenoid HELP!!  (Read 1423 times)
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
I am deferring to the many other mechanics here that would know more about my truck than I do.
Trouble code= p0740  Torque converter clutch code.
symptoms= not locking up in overdrive and the new symptom today was not shifting properly.  It goes from a red light but it does not shift to 2 unless i let off the throttle and violently goose it.  Then it shifts.
I know what the code means and I know my way around a vehicle.  It's mud season here and I'm not going swimming until I know what to look for.
What am I looking at here?  Any ideas?
333:  Think "Shakeweight".
Re: 1997 Dodge Dakota 4x4 OBD code p0740 torque converter solenoid HELP!!
« Reply #1 on: March 01, 2013, 02:23:41 PM »
checked the oil level?
Offline Xnavylfr
« Reply #2 on: March 01, 2013, 03:09:03 PM »
Some of your shift solenoids are EXTERNAL on the body of the tranny and others are mounted internally behind the filter. You'll have to check your manual to find out which solenoid is going out or maybe ask a DODGE mech which solenoid it could be and where it is???  If it's internal you can count on , a filter and about 6 QTS of fluid + the cost of the solenoid..
Hope this helped some!!!
Xnavylfr(CHUCK)
Offline dusterdude
« Reply #3 on: March 01, 2013, 05:53:22 PM »
They are inside,no big deal to change.buy em from cascade transmissions dot com,they sell an updated borg warner unit.you should buy the o/d solenoid too
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #4 on: March 01, 2013, 05:53:59 PM »
Btw,only use atf+4 also
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
