Author Topic: Sandcast 4286 Project  (Read 161580 times)
0 Members and 9 Guests are viewing this topic.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: Sandcast 4286 Project
« Reply #500 on: February 27, 2014, 04:57:17 PM »
Back from the zinc plater.  Took less than a week, and they look great!  Electro-plating specialties in Hayward, CA.  All this cost $145 out the door.  I'm stoked.
« Reply #501 on: February 27, 2014, 06:00:59 PM »
Good deal, Greggo!
Offline goldarrow
  • one day, i'll be an
« Reply #502 on: February 27, 2014, 06:13:38 PM »
Looking really nice!  How do they charge? By the lbs?
CB550 K0
Offline Greggo
  • Somebody's
« Reply #503 on: February 27, 2014, 06:21:43 PM »
He just looked at it and gave me an estimate..no weighing or counting.  I was expecting to pay a little more really :)
Good deal, Greggo!
For sure!  I maybe shouldn't have bought the extra Yamiya bolt set..oh well.
Offline Greggo
  • Somebody's
« Reply #504 on: February 27, 2014, 07:21:21 PM »
Nice putting a few things together with new stuff..
Offline tweakin
  • tear down
« Reply #505 on: February 27, 2014, 08:14:24 PM »
Looks great Greggo! Really like the freshly plated bits.  Added that place to my book marks for future projects.
Offline Greggo
  • Somebody's
« Reply #506 on: February 27, 2014, 08:34:49 PM »
Thanks! The brake rod and engine hangars were done too.  My final Yamiya order, and my piston rings from CB750supply should be in before I get to the shop this weekend.  The head from Bill arrived today, and I also got my swing arm bushings this week from the german ebay seller.
« Last Edit: February 27, 2014, 08:38:17 PM by Greggo »
Offline Greggo
  • Somebody's
« Reply #507 on: March 01, 2014, 01:41:38 PM »
Couldn't do any work on the motor today, so I got started putting other things back together..
Horn's back together and installed.
Battery box
Tool Tray
Seat
Seat latch reassembled and installed
Ignition Switch
I need to do some research on the harness routing.  I've been using a parts manual to use the correct sized bolts, washers and other bits in the right places.  It's really been helping, and there are LOTS of different sized pieces.
« Last Edit: March 01, 2014, 06:12:49 PM by Greggo »
Offline Greggo
  • Somebody's
« Reply #508 on: March 07, 2014, 03:04:49 PM »
I dropped off the chrome bits at that plater and got a quote.  I'm glad I found these guys.  I did end up not having him do the gauge backs because they were too badly pitted.
19 pieces for $460 out the door is a smokin' deal in California.
« Reply #509 on: March 07, 2014, 05:11:43 PM »
EPA charge? Effin Cali...never have seen that. That does seem like a good deal Greggo, I was quoted $200+ for a 550 front fender a couple years back [ended up buying a good one for cheaper].
I'm getting two mufflers chromed for my K4 now [$185]
Offline Greggo
  • Somebody's
« Reply #510 on: March 07, 2014, 06:32:24 PM »
I know, California taxes, right!? I talked with the guy doing the work, and it's going to be a lot of work for him, so it really is a great deal, even with the tax.
Offline edwardmorris
  • Youngish
« Reply #511 on: March 08, 2014, 11:11:05 AM »
Wow, Cali is expensive. WIll have to see when the parts are back. The gold standard is Brown's plating. If they're comparable, then that bill is about right. On the other hand, if you're looking for a "renewed" finish on the parts that are visible (polish and plate outsides of fenders, risers etc.), Calco Plating in Chicago is the best bang for the buck. $1000-$1200 for EVERYTHING CHROME on a 750, down to nuts and washers but no pipes. Pipes with heatshields themselves are about $700 I think.
« Last Edit: March 08, 2014, 11:12:50 AM by edwardmorris »
Offline Greggo
  • Somebody's
« Reply #512 on: March 08, 2014, 04:34:49 PM »
I've seen their finished products and they are top notch.  He's going to fix all the blemishes, buff, polish, and re-plate everything.  They will look brand new, or they don't accept the job was the feeling I got from speaking with the workers.
I got a few things done in the shop, including stripping the nasty caked on black paint off the cylinders, and giving them a few coats of Duplicolor DE1615.  I also put new screws and titanium nuts on the tappets.
« Last Edit: March 08, 2014, 05:01:37 PM by Greggo »
  • Youngish
« Reply #513 on: March 08, 2014, 05:29:42 PM »
Very nice! Please post some pix when you get them back.
Offline Greggo
  • Somebody's
« Reply #514 on: March 08, 2014, 08:15:36 PM »
No problem!  He said he needed two or three weeks, so I should have them back in less than a month.
My swing arm, center stand, and kick stand will be back from the painter Monday.  He's got to repaint the oil tank, as it was flat and completely lacking gloss, I don't know how I overlooked that when I saw the first batch.  Luckily that was the only part needing a redo.  With the swing arm back I'll be able to push in the new bushings, and slip it into the frame with the new rear shocks.
In other news, I'm pretty much bike-money broke, and will still need to pay for the work on the cylinder head, and tires to finish this bear of a project.  I'm going to put it together with a different tank, air box, beat up fork ears & headlight bucket until I've broken the motor in and can pay for the paint job.
Offline Greggo
  • Somebody's
« Reply #515 on: March 15, 2014, 03:26:57 PM »
There has been one universal truth with this project: Everything takes frigging forever.
It's starting to look more like a bike.  Swing arm got fresh brass bushings pushed in..pivot tube cleaned up, and I had to snag the zerks off my K4 (which is stored away, and took friggin' forever to get out) to get the whole thing lubed up.  With the swinger installed, I was able to get the shocks and center stand on as well.
« Reply #516 on: March 16, 2014, 06:46:24 AM »
Hey Greggo - yes, when you are doing a restore at such a high level, such as yours, it does take a long time (unless you can devote 8 hours a day to it).
The cosmetic restore to my Z1 took nearly a year, and was nowhere near as complete as yours.
Hopefully you are not in a rush to finish, that is usually when the quality of craftsmanship starts to slip.
Offline tweakin
  • tear down
« Reply #517 on: March 16, 2014, 06:57:45 AM »
Excellent work Greggo!  I agree with Stev-o, high level builds can't be rushed if you want the results I know you are after.  I love how this bike is coming together.
Offline toytuff
  • "watching the pinheads"
« Reply #518 on: March 16, 2014, 07:08:58 AM »
Slow and steady Greggo.  ;)
tt
Offline Greggo
  • Somebody's
« Reply #519 on: March 16, 2014, 07:19:27 AM »
Thanks guys..I'm trying to be patient..
The head is off at a machine shop, so I know it won't be long before I have the motor back together and ready to put in the frame...then I'll really start feeling better about it.
« Reply #520 on: March 16, 2014, 07:23:53 AM »
Did you blast the head before rebuild and do you plan to paint it? Was unpainted from the factory, right?
Offline toytuff
« Reply #521 on: March 16, 2014, 07:35:27 AM »
We already feel good. You should too!  :D
tt
Offline Greggo
  • Somebody's
« Reply #522 on: March 16, 2014, 07:51:58 AM »
Did not blast it, but I will be painting it the same as the cases and cylinders.  I've read from Hondaman that they were unpainted from the factory, and that's why so many of the early ones corroded so quickly.  Paint seems to be the norm/acceptable for restorations on SOOC, so that's kind of my guide.
I'm considering redoing the wheel hubs and fork legs...they came out too light/white looking, and lost any resemblance to brushed aluminum.  I have an extra set of K0 hubs I'm going to strip off the factory clear and see how they look.  It could end up meaning a lot more work to do, but I saw a pic of a red sandcast put together with similar looking forks, and the whole bike looked wrong...they have to have that brushed aluminum look.
« Reply #523 on: March 16, 2014, 08:17:11 AM »
Would soda blasting the hubs/lowers give you the look you want?
Offline Greggo
  • Somebody's
« Reply #524 on: March 16, 2014, 08:30:40 AM »
I think that would make them flat like the bead blasting did..I'm going to use paint stripper to remove the factory clear, and see how nice they are underneath.  If they're nice and silvery I'll figure out if I want to do more than just have them clear coated again.
