Well for those following my saga, I got the bike put back together today - started right up, no issues...it's been sitting for about 2 weeks. So I shut it off and then start smelling gas....see the #3 carb dripping out of the pod, so I close the fuel petcock and tap on the float bowl...start back up, running ok. Decide to take it for a spin to see if all the wrenching I did made any difference (valves and cam chain adj, points gapped, new plugs, cleaned and ohm's the spart plug caps, new spark plugs (properly gapped), oil & filter.
So I get it on the road and immediately notice the idle hanging high then dropping slow to normal and it's got like 1/2 power...it's just rolling up to speed and struggling to make any noticeble torque....get it back to the camper and I start unplugging spark plug wires....pulled #1 no difference, pulled #4 no difference....pull either 2 or 3 and it dies. So I figure I have no spark to 1&4. I pulled the tank and separated the yellow, blue and black/white leads from each of the coils and checked continuity of both coils...both good. I checked continuity between 2&3 spark plug caps and got nothing, switched to Ohms and got either K Ohms or M Ohms, don't recall....did the same check on 1&4 spark plug caps (it was no contiunuity and one of the above ohm readings)......I figured I would double check my point gaps and verified both at .014" at highest opening....I did not make any ajustments to timing plate for either cyclinder since it last ran (quite nicely I might add)
SO, I'm stuck...I don't understand where my 1 and 4 cylinder are....HELP PLEASE I need this thing to go today!
