Author Topic: Re CB350 Pistons in CB750  (Read 1179 times)
Offline chris
« on: March 05, 2013, 03:26:31 AM »
Can someone tell me if its ok that you can put CB 350 pistons in a CB750 which brings the capacity out to 800 plus ccs.If so what are the fors v against thanks Chris
Re: Re CB350 Pistons in CB750
« Reply #1 on: March 05, 2013, 11:25:33 AM »
812cc
Domes have to be cut.
Offline chris
« Reply #2 on: March 05, 2013, 12:54:26 PM »
Thanks Jerry  Is that because the compression is too high and how much should it be cut
« Reply #3 on: March 05, 2013, 02:48:08 PM »
1 mm over is 836..
.I have a better idea.. I will use old 900 and 1000 pistons to build bore kit for CB 350, if I can get rings..
