Author Topic: Speedometer Tachometer Gauges Cushion Gasket  (Read 3693 times)
Offline Kenzo1979
« on: March 05, 2013, 03:01:08 PM »
Here's a good idea for DIY speedometer and tachometer cushions:
You can use a large O-ring like the one off of your old oil filter.  I used the O-rings from a couple old 500/550 oil filters for my 350K4.  They're perfect for the early style gauges.  You can also try vacuum cleaner belts.  I used a few of these on my 500K1.  Both keep the gauges secure and look pretty good as well.
Later style gauges are a little larger, but I'm sure you could still make it work.  Here are some pics (the 1st is the 350 with oil filter o-rings, then the 500 with vacuum belts, and last is stock 550 just to show the difference in the gauges:
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
