Author Topic: Arg! Help with 836cc kit ???  (Read 747 times)
Offline Hummel
« on: March 07, 2013, 01:17:20 AM »
Now i Was called by my engine builder and i asked me about the sleeves. It seems to by very thin in the part there is going down in the engineblock. He said if he bores out The sleeves to 65mm there Would be 1,3mm in each side.
Is this normally when you bore you stock to 836cc ?? And is it enough ??
Hope you get it and would help.
Thanks Tommy
Re: Arg! Help with 836cc kit ???
« Reply #1 on: March 07, 2013, 07:20:56 AM »
Yes that part is thinner..its been done a Thousand times before,will be fine.
« Reply #2 on: March 07, 2013, 07:45:18 AM »
10s of thousands.
The 836 size is most popular, but the sleeves will handle 850cc as well. Above that you have to bore the aluminum block and resleeve .
Offline Hummel
« Reply #3 on: March 07, 2013, 09:23:09 AM »
Thank you very much! I panic a bit when he told me it wouldn't work. But I will call him tomorrow and say go for it ! :)
Again thank you guys
Tommy
Sent from my iPad using Tapatalk HD
« Reply #4 on: March 07, 2013, 08:43:21 PM »
Chamfer the bottoms..be carefull handling them, the sleeves are thin..
Offline MattFreeman
  • What Have I Done?
« Reply #5 on: March 08, 2013, 06:53:52 AM »
+1
I put a flat spot in the lower part of the sleeve setting them down. That was a pricy misjudgment.
