Author Topic: CB750 Intake spigot sizes  (Read 3454 times)
« on: March 07, 2013, 02:16:08 PM »
I did not know there was more than one thread size where they join the head.I sent an early one to a member and he said it fell in.
 So are late F model bigger or are the threads just stripped?
Offline kmb69
Re: CB750 Intake spigot sizes
« Reply #1 on: March 07, 2013, 02:24:26 PM »
F2 and F3 spigots are about 2mm larger.
Offline Old Scrambler
« Reply #2 on: March 10, 2013, 05:29:38 PM »
Is the OD the only thing that is BIGGER?  My F2 head is on ice for the winter so I will have to wait a few weeks to get to it. It would be interesting to know if the ID of the intake ports and spigots are also larger than the standard K-models.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
  • Moderator
« Reply #3 on: March 10, 2013, 05:32:37 PM »
Where is Mike when you need him. ;D ;D ;D ;D
Sam. ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #4 on: March 10, 2013, 05:36:38 PM »
I just looked in a 410 /F2 head,nice and smooth and looks bigger,port sticks out in the way,just match to spigot would help!,Can shoot pic if you like,or measure! ;) ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline kmb69
« Reply #5 on: March 10, 2013, 07:23:55 PM »
Ports, valves, all bigger.
« Reply #6 on: March 11, 2013, 04:29:32 AM »
Better port casting as well.
Offline Cqyqte
« Reply #7 on: March 11, 2013, 04:44:55 AM »
I would be interested in knowing if the OD of the 1975 F spigot where the intake rubbers clamp is different than the 1978 F or K OD.  As I have 1978 carbs that I want to fit to my 1975 and I don't have any boots.
« Reply #8 on: March 11, 2013, 07:25:16 AM »
Thanks guys.............now to find some high-compression pistons to match the dome.....but no more than a 0.5mm overbore.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #9 on: December 06, 2014, 09:11:19 PM »
Sorry to dredge up an old thread but, is it possible to fit F2/3 spigots to a K7 head by tapping new threads ..?
Offline Big Jay
    • CBRzone
« Reply #10 on: December 06, 2014, 09:26:28 PM »
On the K heads, there are two different thread pitches.
Offline kmb69
« Reply #11 on: December 06, 2014, 09:28:24 PM »
Doubt if you could just tap them bigger. They are a good 2+mm larger. It's a very fine pitch thread. Probably have to be machined bigger and then rethreaded. Certainly doable.
« Reply #12 on: December 06, 2014, 09:34:15 PM »
Thanks mate, thats what i meant, i figured in the HIPO section i wouldn't have to fill in all the blanks.... ;D ;)
« Reply #13 on: December 07, 2014, 11:39:31 AM »
Retro...............I measured the ID of the F2 spigots at 31mm................then bored them to 33mm for my salt-flats motor;D ;D ;D
To improve the intake potential on a K-head, I would think it would be easier to bore the spigot to match the porting. JMR may have some more input, but I would want to know how much larger the port on a K-head can be expanded before I attempted to bore and re-thread the F2-F3 spigots.   Then again, you could re-do the ports to follow Ken at Cycle-X ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #14 on: December 07, 2014, 09:04:21 PM »
Old Scrambler, I'm going to run fuel injection off a GSXR600 so i was just feeling around, the ID of the throttle bodies on the head side is 38mm and OD is 43mm so bigger diameter spigots and manifolds would help. I would also like to know how far the K8 {392} ports can be opened up and if i can then use F2 spigots... ;)
