Author Topic: Where to stop on F2 engine?  (Read 567 times)
« on: March 08, 2013, 04:10:45 AM »
The F2 engine I am working on - I know nothing about it except it had good numbers on all four cylinders  in the compression test.
I pulled the head due to the F2 reputation and it needs valve job alright.
Now I am wondering where should I stop - should I take jugs off and disassemble the transmission?  The cam chain is in good shape, the guide too, I would think it has less than 30 000 miles on it, more like 20 000.
The transmission shifts fine and spins freely, there was nothing in the pan - like metal shavings.
What is  your thought on it?  I can play with it for a year or two but money is short  as always.
Re: Where to stop on F2 engine?
« Reply #1 on: March 08, 2013, 04:39:13 AM »
Be careful of those rings,aren't they the ones that are hard to find ??
« Reply #2 on: March 08, 2013, 04:44:00 AM »
Yes, they are, that's why the jugs still sit on the engine.
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #3 on: March 08, 2013, 06:00:37 AM »
I would probably check the stretch of the primary chains - the manual tells you how to do this - and, if it is well within specs, do what is needed to repair the head and then reassemble. The worst that can happen is to experience major mechanical noises on startup requiring a bottom end rebuild. Pat
Regards
Pat from Australia
