Author Topic: Restoring tank emblems  (Read 3057 times)
Offline longshanks
« on: March 14, 2013, 12:16:46 PM »
Anybody have a method for restoring emblems to somewhat factory look for a CB450? Do you have to use model paint and a small brush to get the letters white again?
cb450 K5
Offline harisuluv
Re: Restoring tank emblems
« Reply #1 on: March 14, 2013, 12:24:17 PM »
Yes that seems to be the case.  I didn't exactly get the white the exact color last time I did it but it was hard to tell.  I think I media blasted (paint was HARD and on there GOOD) and then did the lettering, taped off the lettering and then sprayed the black.  Something like that.
Offline longshanks
« Reply #2 on: March 14, 2013, 12:35:15 PM »
Wouldn't it be easier to paint black first and the brush in the lettering?
cb450 K5
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: March 14, 2013, 12:36:28 PM »
Sharpie paint pens work quite well and they are available in different colors and points...Larry
Offline harisuluv
« Reply #4 on: March 14, 2013, 12:38:55 PM »
Yeah but I thought the black would bleed through.
« Reply #5 on: March 14, 2013, 01:26:39 PM »
+1
spray them white, and then brush on the black.
I had some spraymax2K leftover, so I coated mine.
Offline wowbagger
  • Not much of an
« Reply #6 on: March 14, 2013, 01:48:23 PM »
I've read that soaking them in acetone will life the old paint off pretty easy. Then, repaint with model paint and brushes or sharpies paint pens. A q-tip dabbed in acetone will clean the raised edges back to the original chrome.
« Last Edit: March 14, 2013, 02:10:13 PM by wowbagger »
Offline Whipsaw
« Reply #7 on: March 14, 2013, 02:09:14 PM »
For the white inside areas you can thin down some white paint till its like water, then using a small brush dab it in and it will run to fill the area by itself.  I have done this for years even when I was building models, works like a charm....once the solvent evaporates you have the white paint just where you want it...
"It's a sin to squish old tin!"
Offline longshanks
« Reply #8 on: March 14, 2013, 02:09:29 PM »
This is for a 450 so the white lettering is set inwards(not my pic). So what I gather is:
-spray paint white
-q tip the chrome letter edges with acetone
-sharpie paint the outside black
Yes?
cb450 K5
Offline wowbagger
  • Not much of an
« Reply #9 on: March 14, 2013, 02:11:02 PM »
Yeaaah, I read tank badge and was thinking side cover emblem. I corrected my post above to avoid confusion.
Offline Whipsaw
« Reply #10 on: March 14, 2013, 02:17:24 PM »
Heres the thinned method on the alternator cover...may work as well for the tank emblem black if careful on the edge areas
Offline RFogelsong
« Reply #11 on: March 14, 2013, 07:40:48 PM »
I used auto touch up bottles for both colors on an emblem like the one in the picture with the green background a couple posts up.  I basically "flooded" the inside of the letters and dabbed when using the black.  The nice thing about auto touch up paint is that when it's about half dry, dragging (not scraping, the sharp edge should be trailing your hand) a razor across the flats gets the paint off there nicely without dealing with acetone that'll run into the black areas when you oversaturate your q-tip.
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline longshanks
« Reply #12 on: March 15, 2013, 10:15:19 AM »
All such great advice here! While we're on this topic, I have some front forks and fork ears that have been painted black and I want to remove the paint. Can I use paint stripper or will it destroy the chrome on the fork ears? What's the best way to get the paint off either part?
cb450 K5
Offline RFogelsong
« Reply #13 on: March 15, 2013, 11:15:50 AM »
Lacquer thinner or acetone works for getting paint off chrome, but be warned, I have not done Honda fork ears with this method.  I don't think you'll have any issues, but hit the back side first.  I'd try the thinner first.
-Rob
DOHC2:'71 CB450K
Offline MoMo
« Reply #14 on: March 15, 2013, 04:40:45 PM »
Lacquer thinner should remove any spray bomb paint and not harm the chrome- worked for me...Larry
Offline longshanks
« Reply #15 on: March 15, 2013, 06:11:51 PM »
Ok, I'll try lacquer thinner. Just apply with a soft rag, nothing too bristly?
cb450 K5
Offline MoMo
« Reply #16 on: March 15, 2013, 08:58:12 PM »
that is the way I did it
