you can buy them new still,to check your rocker shaft wear in the housing remove those two end covers,then screw a 6mm bolt into the shaft thread and try to wobble it up and down and round and round,do this with say #1 on compression and the tappets backed right out,then with #4 on compression with its tappets backed out,you dont want any pressure on the shaft to test it.
