Author Topic: Haha. Wide rear tire  (Read 9160 times)
JWExperience
Re: Haha. Wide rear tire
« Reply #50 on: March 21, 2013, 07:03:19 PM »
Here's a 160x17 on a stock swing arm and it just fits..
My difference is that I'm running a 150 0n a 18" wheel so it pushes my tire further into the swingarm and a tighter space. It almost looks like i need to keep my stock chaing/sprocket setup because the offset might rub on the left shock. Anyone else run an offset sprocket on 76 swingarm or know if it is even necessary?
Offline andrewk
  • doin' it.
« Reply #51 on: March 21, 2013, 07:14:58 PM »
You might want to double check your engine numbers and make sure you don't have a late model engine (and rear sprocket carrier) already.  Stranger things have happened.
JWExperience
« Reply #52 on: March 21, 2013, 07:17:05 PM »
I looked closer at the hub and compared to the pictures on cyclex and it looks like a 69-76 hub. Do you know off hand what the numbers on my motor should be if its earlier?
