Author Topic: How perfect should I expect my clutch to be? (350F)  (Read 1783 times)
Offline dougan
    • Whobrew.com -- Free resources for home brewing
« on: March 17, 2013, 12:22:57 PM »
I'm going to be getting my bike out of storage in the next few weeks and getting my pre-season maintenance done.
I've always suspected that my clutch needs work but I'm not sure if it's just a result of having a bike that was made in the 70's or if there is really an issue.  I don't feel like cracking it open if I'm not going to gain anything.  First, when I pull the clutch in, it feels like it doesn't fully disengage.  With the clutch level pulled in, if I'm in gear, it will still have some pressure on the rear wheel, but it's very, very slight.  Not enough to move me if I'm on the bike with my feet down.  Also, when the bike is at a complete stop, it sometimes doesn't like to shift down into first.  If the bike is moving at all it is not a problem, though-- just while perfectly still.
I'm using that 10w40 valvoline for wet clutches.  I'm going to be changing the oil soon and I plan to use that again.  I've already fiddled with tuning the clutch lever and that's not made it better.
So, I don't know, what do you all think, is this typical behavior or do you think I can do better?  Neither of these things is a big deal, just imperfect.
1972 CB350 Four
www.whobrew.com -- resources for home brewers
Offline HondanutRider
Re: How perfect should I expect my clutch to be? (350F)
« Reply #1 on: March 17, 2013, 12:46:57 PM »
You probably can do more.  Take a look at the Honda Service Manual for the clutch adjustments.
« Reply #2 on: March 17, 2013, 12:53:04 PM »
do the full clutch adjustment with the engine hot,after that it might still be a bit draggy when still cold,if you cant adjust it to disengage fully without then slipping under hard power the friction discs will need replacing.
Offline dougan
« Reply #3 on: March 17, 2013, 12:55:23 PM »
Oh, yeah, that reminds me, forgot to mention that everything I described is true when the engine is warm... the clutch sticks worse when it's cold but that I am not worried about.
1972 CB350 Four
Offline ADW
« Reply #4 on: March 17, 2013, 01:03:08 PM »
I'd agree with the other responders. My 350F doesn't behave that way. Service manual adjustment procedure dials it in just fine, so yours should be able to be dialed in per the procedure too. If not then it probably needs work.
« Reply #5 on: March 17, 2013, 01:20:30 PM »
How old is your cable? A stretched cable can cause headaches.  If it's over a couple years old or a cheap aftermarket, get a new one from Honda.
(Pretty sure they are available)
Offline camelman
  • Man... Myth... Legend
« Reply #6 on: March 17, 2013, 07:44:12 PM »
Dougan,
I've written about this before in the posts listed below.  If simple adjustments do not fix your clutch issues, then you might want to remove the clutch drum and smooth the fingers down.  I have had to do this on literally every Honda I've owned to get smooth shifting.  That's a total of 9 different Hondas, and they all had small indentations worn in the clutch fingers.  A simple way to avoid this issue is to not slam through the gears when you are shifting... but where's the fun in that?  ;-)
Scroll down and look for my first posts:
http://forums.sohc4.net/index.php?topic=95809.0
http://forums.sohc4.net/index.php?topic=85893.0
Regards,
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline dougan
« Reply #7 on: April 05, 2013, 02:33:34 PM »
Dougan,
Regards,
Camelman
Thanks, the part you are referring to is #23 here right?
1972 CB350 Four
Offline camelman
« Reply #8 on: April 05, 2013, 02:45:49 PM »
Yep. It looks like you have small indents on at least one side of the fingers. Use a wide file to smooth them out. Go gently!
Offline dougan
« Reply #9 on: April 05, 2013, 04:34:20 PM »
Oh, I should have mentioned this is a photo I found on the internet, not mine.  I'll be cracking it open tomorrow, hopefully while the rain finally washes the salt off the roads. :)
THanks for all the tips, I'll make sure to post back about how it goes.
« Last Edit: April 05, 2013, 04:36:49 PM by dougan »
1972 CB350 Four
Offline dougan
« Reply #10 on: April 06, 2013, 01:42:47 PM »
I went to take the clutch cover off, and found about half of the phillips head screws' heads to be stripped.  I guess I will have to drill them out, which is something I've been able to avoid thus far on this bike (I guess this is probably typical for something older than me).
I've never done this before, though, and I'd feel more comfortable knowing I already have the replacement screws when I do it.  I can't seem to find anywhere in my manual that lists what the screw specs are... can anybody help me get that information?
Thanks!
1972 CB350 Four
Offline camelman
« Reply #11 on: April 06, 2013, 02:09:51 PM »
They are literally called "cheese head" screws and are available at Ace Hardware. Get an impact screwdriver to remove those types of screws.
