Author Topic: Is this right.  (Read 2200 times)
Nic
Is this right.
« on: March 17, 2013, 10:14:54 PM »
Today I was cleaning the front pegs on my newly acquired basket case 750 K2 and noticed they are different. Is this how it's supposed to be or is one of these a wrongun? This can't be right coz the way they are now one foot is further forward than the other.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: Is this right.
« Reply #1 on: March 17, 2013, 11:16:34 PM »
I'm not sure - but wouldn't one be diff to accommodate the rear brake foot pedal?
Nic
Re: Is this right.
« Reply #2 on: March 17, 2013, 11:48:45 PM »
I was hoping someone with a similar vehicle might just go n have a look????
Re: Is this right.
« Reply #3 on: March 18, 2013, 12:01:51 AM »
even the 500/550 ones are different,lots of bikes are.
Re: Is this right.
« Reply #4 on: March 18, 2013, 12:12:11 AM »
It is normal, been a few frames that photos show this recently, it drives those attention to detail nuts over the edge. Want to really twist your head around it, look at the 70s BMW boxer motor designs.
David
Offline trueblue
Re: Is this right.
« Reply #5 on: March 18, 2013, 01:35:18 AM »
My 350 twin has a good couple of inches difference side to side.  The right side is set forward to allow the kick start to do its thing.
1979 CB650Z
Nic
Re: Is this right.
« Reply #6 on: March 18, 2013, 03:24:42 AM »
Thanks for the replies fellas, it doesn't seem right to me, even if it is so I see no reason why it should be so on the K2, so much so that I'm willing to take to the longer one with whatever it takes to make them the same. I don't see the brake pedal needing the extra length and it's just stupid to have one more forward than the other. It's not like the extra length goes straight up, it's more forward. I'm still hoping someone who has one of these can have a look n report back.
Offline Harsh
  • 74 CB750 and two 72 CB350's
Re: Is this right.
« Reply #7 on: March 18, 2013, 03:30:40 AM »
The pegs on my K4 are just like that.  It is normal.
Offline trueblue
Re: Is this right.
« Reply #8 on: March 18, 2013, 03:41:50 AM »
I was always under the impression that the 750's had the pegs offset for the same reason as the 350, to allow clearance for the kicker.  FYI, my 650Z has no kick starter and the pegs are even ;D.
1979 CB650Z
Offline Johnie
Re: Is this right.
« Reply #9 on: March 18, 2013, 04:28:54 AM »
Welcome to the forum Nic..trust us it is correct. Every 750 I have done are the same. Just be sure you put them back on the correct side. :)
« Last Edit: March 18, 2013, 04:31:07 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: Is this right.
« Reply #10 on: March 18, 2013, 06:26:39 AM »
+1. Look at your motor, it's not the same on each side either.
Re: Is this right.
« Reply #11 on: March 18, 2013, 12:42:26 PM »
i hate you true blue!
Nic
Re: Is this right.
« Reply #12 on: March 18, 2013, 01:52:03 PM »
Thanks for the welcome Johnie, well there's proof positive, I guess I'll just leave em as they are then although mine are bent somewhat, I'll need to fire up the oxy. Thanks to all who replied.
Offline trueblue
Re: Is this right.
« Reply #13 on: March 19, 2013, 04:46:53 AM »
Gee that's a little harsh, just because I own an example of the best SOHC bike Honda made ;D
1979 CB650Z
Re: Is this right.
« Reply #14 on: March 19, 2013, 01:02:16 PM »
no worries Mr perfect footpeg.
Re: Is this right.
« Reply #15 on: March 19, 2013, 02:29:40 PM »
You finally bought a 750....?   8)
Offline trueblue
Re: Is this right.
« Reply #16 on: March 20, 2013, 03:15:20 AM »
No, why would I buy a 750 when in standard trim the 650 is just as quick 8), it also came standard with dual front discs, rearset pegs, electronic ignition and a charging system that actually works ;D.
1979 CB650Z
Offline george
  • Back To My Roots !
  • K8 The Project
Re: Is this right.
« Reply #17 on: March 20, 2013, 10:53:08 AM »
They are different from the factory , and I have seen many with a slight forward bend on the right peg from repeated strikes from the kicker, usually you will notice some matching marks on the peg bracket and the kicker . Hung me up also , just like the left shock on my K8 being about 20mm out more!
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
Re: Is this right.
« Reply #18 on: March 20, 2013, 01:24:50 PM »
Hmmmm, never had a problem with a 750 charging system but i could point you to a few threads about failing 650's.... ;D ;D ;D
Touche.... 8)
