Author Topic: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'  (Read 78361 times)
Re: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'
« Reply #25 on: March 20, 2013, 03:17:56 PM »
I never have missed your point RR.. What matters to you wont matter to EVERY one else.. Yeah I like track days.. Vintage flattrack and drags..... Hard cornering .. Is just not what some of us do..
« Reply #26 on: March 20, 2013, 03:25:43 PM »
Your all hung up on "hard cornering" Frank, i've stated a million times that i can scrape the pegs doing a u turn on these old Honda's , lowering them restricts them even more,  its also a safety issue , if you read my comments, the OP was going to put progressive springs in the front and lower the back, thats what i commented on, he has since changed what he said. I'm growing very tired of having this conversation mate....
Offline Tsunami
  • There's No Place Like This Place Any Where Near This Place So This Must Be "THE PLACE"!
  • Life's to Short, Carry On!
« Reply #27 on: March 20, 2013, 04:35:34 PM »
Hey boys, play nice.  I can see you two have had a long and lustrous relationship and I suspect down deep you both respect each other quite a lot. Ken had already straighten me out on the progressives it just didn't show in the order I pasted correctly.  As I am already raising the rear with an 18" wheel and larger tire an inch lower taint much. Rear sets and no center stand, well I venture I could go lower than stock?  So come up with a good way for me to make some sort of headlight bracket for the brass bucket like the old ones I showed earlier.  If you look at the old brackets (not mine by the way) you can see how the brackets on the side of the light slide down onto the light holder brackets.  Some sort of clamping around the forks instead of ears seems in line. Oh yes, the dia. of the lens, or rind ID is about 9.5"  I'm still trying to find my link to the old ford reflectors but I thing the OD on those was 8".  I'll post a pic when I find it.
[Tsunami Build Link]
CL450 early 70's
New 1973 CB750 Flake Sunrise Orange
CB350 Chopper early 70's
CB350 Cafe' early 70's
Honda Cub 90cc late 60's
Other's
Offline Tsunami
« Reply #28 on: March 20, 2013, 06:07:19 PM »
9.5" lens, may have found what I need at  http://www.classicandvintagebulbs.com/page3.html
BA15
CL450 early 70's
Other's
Offline Tsunami
« Reply #29 on: March 20, 2013, 06:45:06 PM »
these are 9.25 but come as a set.  I just ordered a BA15d in a 12v 50w format curious to see if it puts out enough light.
CL450 early 70's
Other's
« Reply #31 on: March 20, 2013, 09:12:24 PM »
Some 750 trees have 2 holes in the lower..like 77 and 78.. You can make studs, with threaded ends and mount them similar to early bikes.
Offline Tsunami
« Reply #32 on: March 22, 2013, 06:00:51 PM »
my picture of my lester, picked up a gl1000 front end, mocked up my lester, appears to be the ticket. I don't have gl information. Ill go search but need amount of fork oil, what kind, weight?
Thanks guys
CL450 early 70's
Other's
Offline SF
  • I burn gas very well
« Reply #33 on: March 23, 2013, 05:03:15 AM »
like the way your going with the bike. thanks for the link to vintage bulbs. i was looking for bulbs for my shovel project.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline brandEn
« Reply #34 on: March 23, 2013, 08:27:23 AM »
Check out this article from GL1000 expert Randakk.
http://www.randakksblog.com/removing-stiction-from-gl1000-front-forks/
should give you some good info on those forks. I have a GL front end on my F3 and used this guide.
Offline Tsunami
« Reply #35 on: March 23, 2013, 11:03:41 AM »
I finally found a state side link, if you know what you need check http://www.bulbtown.com/
CL450 early 70's
Other's
Offline Tsunami
« Reply #36 on: March 23, 2013, 11:08:58 AM »
BrandEn, great link thanks so much, that should take care of my fork issues when I get hot on the fork/brake rebuild. That goes in my link library. Now I have to find all the fork and brake parts.  And I thought boats were money pits!  Thanks again
CL450 early 70's
Other's
Offline brandEn
« Reply #37 on: March 23, 2013, 12:26:12 PM »
Glad to help!
Offline Tsunami
« Reply #38 on: March 27, 2013, 08:11:02 PM »
Just an update, I have had some work this last week, As Manard G Kribs would say WorrrrrrrrrK! Anyway, finally scored a rear Lester, paid too much but at least I can move on with this. Disassembled the 77 GL1000 front end except the insides of the forks.  Both Caliper pistons were stuck, used grease gun to get one out and blew up the grease gun on the other.  Sent off the Rotors to Jeff Stephen's in Wisc. to drill and take off some weight.  Gonna try some of those funky pistons he makes, much lighter.  He gave me a tip use the master Cyl to get the piston out, duh, the things I know but have forgotten!  Worked like a charm, think I should send back the new air driven grease gun?  Ordered up a SuperBrace and all the seals, wipers and covers.  New EBC organic pads coming.  Received the X2-11 NEW CHROME FORK SEAL PROTECTORS from Willies Cycle, probably wont be able to use them with the brace. But they look great.  Started stripping down the gauge's, got LED's for the gauge lights and new face plates but opening up those cases looks daunting.  Had hoped to have my stuff back from Cycle X but not done yet.  Id been checking every week or so on progress but now have stopped calling and started praying instead. LOL  So now I'm on the great bearing chase for my Lester's.  Well back to WorrrrrrrrrK!!!!!!
« Last Edit: March 27, 2013, 08:14:21 PM by Tsunami »
CL450 early 70's
Other's
Offline Tsunami
« Reply #39 on: April 07, 2013, 11:21:16 PM »
I hate that oversized file message then lose everything including text! Arrrrrrgh!
Again, just an progress update.  Both my Lesters are here and will be removing tires tomorrow.  Still cannot make up my mind what which way to go with them.  I had wanted to Black out a lot of stuff, but doesn't most everyone do that?  I'm leaning towards Brass and Chrome.  I think often its easier to paint things black than get creative, hey that's just me the 600 lb gorilla in the room.  Anyway got the seals out of the forks, replacement parts are in. Got my drilled and lightened rotors back from Jeff they look great.  The new pistons are very light.  Ordered a new Nissan master cylinder as there was no stock gl one and the cb is undersized for the duel disc's.  I noticed that my swing arm doesn't have stock bushings in it?  Its a solid tube? I'm in buff mode on the front end parts now, grubby anal work but I think the results are worth it.  I'm pooped, long day, its 11:15. Hope you all had a good weekend. Bear out!
CL450 early 70's
Other's
Offline Tsunami
« Reply #40 on: April 19, 2013, 09:50:56 PM »
Hi Guys, been off site for awhile, life getting in the way.  Got some work for awhile, wife's closet hanger bars came down so made bullet proof hangers from 1/2" black pipe which I major anchored to the house. Not pretty but wont ever have to do that again.  Also in the middle of a 40' wood fence build. I have to get 7 2' deep post wholes done in very rocky ground so I cant use a gas auger. Have to do it by hand, got 3 dug and set, 1 other dug but not set.  Pain in the arse.  I'm too old for this but somebody has to do it.
Back to the fun stuff, got a lot of my cycle x stuff in will have pictures later, also decided on a tail light.  Its after market for something like a newer 2007-2012 CBR600RR?.  Its led and has sequential turn signals built in.  Its a bit long for my Razor back seat so will likely French it into the rear about 3 Inches.  Got a lot of my parts buffed out by the 11th.  Tires finally on the way from the Old Bike Barn, Great people over there and good prices.
CL450 early 70's
Other's
« Reply #41 on: April 19, 2013, 11:43:07 PM »
Forget everything i said about your suspension, you have picked the worst possible tires money can buy, seriously people, why buy those absolutely useless tires just for looks..... ::)
Offline Tsunami
« Reply #42 on: April 21, 2013, 03:19:18 PM »
Retro I'm so relieved you like the looks of my tire choice.  It really felt nice to get rid of that Euro stuff everybody runs.  It seems there's a lot of stuff people do on here that you just don't get? They say the world spins a little slower at the South Pole, need I say more!
CL450 early 70's
Other's
« Reply #43 on: April 21, 2013, 05:30:12 PM »
Ok clever one, tell me why they are a good choice ?, Yeah, i know, they LOOK good  ::) . I don't get people putting cheap sh1t tires on a bike that will increase your chance of having a spill, I am very serious about suspension and tires on bikes, i like mine to stay upright, so  far as spinning a bit slower, go off and learn something by reading some facts.  Sounds like you are one of those people that are offended by people that know more than you....  HIPO Engine work, lesters, cafe and sh1t tires , sounds like a great combination to me....
And really, i don't give a fcuk what you do, i started out giving you some good info about shocks and suspension, now i'm telling you, those tires are for looks, they track badly {follow lines in the road}, have a shocking shape giving the feeling of falling into corners and they let go without warning, they are also deadly in the wet...  To me, you seem like a noob with no idea .... Have a nice day....
« Last Edit: April 21, 2013, 08:18:19 PM by Retro Rocket »
Offline Tsunami
« Reply #44 on: April 21, 2013, 09:18:36 PM »
 :o MY My a little testy down under are we.  Who asked you in the first place! I'm not going to get in a pissing contest with you.  You don't matter, so go peddle your misery on  some others thread.  With over 11,000 post you must not have anything better to do.  You don't know or understand what I'm doing, its only important that I do, so shut the f**k up!  Sic semper tyrannis !!  :-* my butt.
 My apologies to the rest of the forum but I didn't start this and it will end here with me, this guy is persona non grata to me.
CL450 early 70's
Other's
Offline johno
« Reply #45 on: April 22, 2013, 05:44:34 AM »
Well, the important thing here Sunami is to finish the build, as I suspect everyone on the forum will want to see the work of art , I do.   So push on Mcduff cant wait to see it all come together. ;) ;D
johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
« Reply #46 on: April 22, 2013, 03:45:27 PM »
Sorry dude but you started it by getting personal , remember this
thanks for the info,
You seemed to appreciate my help earlier on when it suited you..? I generalized about those firestones and you seem to have taken it personally,  you said "They say the world spins a little slower at the South Pole"  and got all sarcastic,  I just pointed out what a lot of people already know, crap tires, I think your a bit weird  :o....
' You don't know or understand what I'm doing"    Oh yes i do, i already pointed that out, hipo engine mods, better quality wheels and the worst possible tires that money can buy, awesome strategy ....
I am sorry mate, if i had known that your ability to absorb information was so inadequate and you were incapable of understanding what i was saying, i would never have bothered you. I know you , at the first sign of disagreement you try and get personal with the name calling and personal stuff, well done, but once again, your just inadequate. I know and understand perfectly but i think your struggling. Its a forum fool, you may have to go look that up as well, if you don't want comments DON"T POST IT ON THE INTERNET   :o  chucking a tantrum because you don't like what i've said kinda says a lot....cause i was talking about the tires, not you... ;D  Anyway, Thanks for the laughs.... :o   I help lots of guys here but you aren't worth my time....  Oh and just remember, you guys invented rednecks ,  we are closer to the equator, we actually spin a little faster here.... ;D   Hey i won't be back, yell and scream and swear  all you like. it'll only make me feel better.... ;D ::)
« Last Edit: April 22, 2013, 03:50:38 PM by Retro Rocket »
« Reply #47 on: April 22, 2013, 04:26:30 PM »
I have absolutely no dog in this fight but I couldn't stop from laughing at RR's comment "Oh and just remember, you guys invented rednecks."
Good times!
  ;D
Offline Tsunami
« Reply #48 on: May 26, 2013, 02:19:07 AM »
Finally, Got the new plate.  Two days and 4 trips to the DMV. OUCH! Got notice that the plate was in, went down with paperwork but DMV would not assign to bike as it was non-op so I said fine lets op it and bring the registration current so I can get the new plate. NOPE cannot du without having insurance.  Ok Fine went home signed up for insurance.  Came back the next day, wait got another fellow who says well yes you have insurance but there is nothing in this policy I got offline to indicate what it was for.  Ok fine, get name and fax # of fellow, go outside call insurance company, now Im sitting in an un air conditioned car, too noisy for the cell phone wait through 3 people, get it all straightened out, go back in. Ok Fine but must pay a $14 fee as well, ok fine, nope cannot take it here have to go next door to an insurance firm and have them take the money???? Ok Fine went next door, they understood no problem we will just bring it up on the old computer, go to DMV site, nope DMV site says it is not needed no $14 fee required. So take it all back to DMC fellow confers with two supervisors who say have to mail it all in!  Hmmmm???? Ok fine. Mind you every time I have to go to the window I have to wait upwards an hour or more.  So off I go home bewildered as can be.  Read up on the three different methods and decided to Call the powers to be.  Reached central call center in Fresno, lady says what I and the insurance guy know, don't need the $14 deal, just pay the $81 regs. fees, give them the proof of insurance and the old plate!  Said I tried but no go.  She goes to super, super calls other super in the DMV branch, puts in the fix!  Go back to branch, get it almost complete, have plate in hand when this knucklehead reads the fine print on the proof of insurance and the Vin # reads CM750xxxxxxx instead of CB750xxxxxxx, typo?  Told the guy to man up and get this settled, he looked around and whispered-oops missed it, see ya- poof Im gone.  Anyway I have a new Avatar, so you wont have to look at my lovely face anymore.
CL450 early 70's
Other's
Offline BPellerine
« Reply #49 on: May 26, 2013, 12:24:36 PM »
good to see you back nice plate no.bill
1978 CB 750K ard and webers
another anfob
