Author Topic: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'  (Read 77122 times)
Offline Tsunami
  • There's No Place Like This Place Any Where Near This Place So This Must Be "THE PLACE"!
  • Life's to Short, Carry On!
Re: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'
« Reply #425 on: April 11, 2017, 07:45:20 PM »
Today's update.  My upper brake hose came yesterday so I installed about an hour ago.  Prepared everything to bleed the brakes however when I go to pumping the brake handle nothing happens when I realized it was not go to work until I find out why I went and removed the furthest hose bolt and  bleeder valve small amount of fluid ran out. both were clear and caliper passed compressed air.   When I pumped now didn't seem to make any difference so I tend to think its the seals in the brake lever?  Allergies wiped me out for the day, so dinner is in the oven and I'll hit it again later or tomorrow.  Installed the two fuel valves and ran some line.  I think I'm going to invest in one of those quick disconnects that also act as a shut off so when I have to remove the tank I will be able too most easily.  If anyone wants to lay into the brake issue, please be my guest.  I'm think that like the o rings in the carb that must of shrank over the years then leaked like a sieve, there may be some rubber in the pump that is not doing its job.   Asta
[Tsunami Build Link]
CL450 early 70's
New 1973 CB750 Flake Sunrise Orange
CB350 Chopper early 70's
CB350 Cafe' early 70's
Honda Cub 90cc late 60's
Other's
Offline Tsunami
« Reply #426 on: April 12, 2017, 12:38:23 PM »
I've check and all my passages are open last night.  I'm about to head to the shop when I checked this post.  Sounds like an idea, Ill let you know how it works out.
Thanks Calj737
Greg
I'm back, so I took your advice and pulled a vac. on it with some mixed results.  What worked better was to crack the banjo bolt an let some fluid run downhill.  So doing I went back to bleeding the system.  I pumped and I pumped and I started to see the MC level go down, that's about the time I noticed fluid down on the rack deck. Oh #$%* now what.  So I back track and find the upper banjo on the right side was leaking, I tightened a bit and tried again, still leaking, closer look it seemed to be coming from the crimp on the hose.  Drained the system again I remove it put on new washers and switched end to end so it would be at the caliper, easier to see. Refilled and that one stopped so now I'm starting to get fluid into the system, the lever even started to get harder, then I see more leaking on the other side.  Couldn't find my .38 or I would have shot it! It was coming from the hydraulic front brake light switch.  Keep in mind this whole front end is off a GL1000 with duels. Tightened it a little could barely get to it but took one of the horns off and managed to get a bit of movement.  Tried it again still leaked! So I drained the system once more and removed it no obvious reason for the leak so now I'm about to go online and see If I can fined a new on and order some more sealing washers. And the beat goes on.
« Last Edit: April 12, 2017, 04:23:19 PM by Tsunami »
CL450 early 70's
Other's
