Author Topic: Crank/Rod brgs. 550 or 650?  (Read 870 times)
« on: March 19, 2013, 09:42:52 AM »
Paulages discovered the CB650 crank can bolt into the CB550 cases so I suppose that should be my answer. However Honda list the 650 bearings as "426" and the 500/550 were listed as 323.
Some of the 550 bearings have been showing up as NLA, and are now being listed as "426" and available.
Have the 323/426 bearings always been identical?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: Crank/Rod brgs. 550 or 650?
« Reply #1 on: March 19, 2013, 10:46:01 AM »
Subscribed for the answer!
« Reply #2 on: March 19, 2013, 12:25:51 PM »
youll have to have a pair in your hand and look at them?maybe oil holes and grooves were altered?but still swappable between the two engines?
« Reply #3 on: March 19, 2013, 01:11:41 PM »
The rod bearings appear to be the same, these were ordered from DSS as 13217-323-003 and arrived as "426." These are for replacement next off season so I can't plastigage until then to know for sure. As I mentioned it also appears (at least on online parts fische) that Honda is superceding to 426 for the rods brgs. so someone must know something?? I find it odd though that identical parts carried two different numbers from 1979 until 2013.
A friend has asked about the crank bearings and I just don't know Dave if there is a slight change between the two.
I have asked DSS and Powersportspro for their explanations.
Offline purf_man
« Reply #4 on: March 20, 2013, 11:32:10 AM »
the  easy answer is don't buy any honda main bearings.....
at least until I get mine for my 550/650 740cc build (sleeves being fitted as we speak...should be sizing my bearings in a month or so)
1975 CB550
1978 RD400
