Author Topic: How to remove tacho needle.  (Read 582 times)
Nic
« on: March 19, 2013, 11:28:20 pm »
Can someone tell me, do you just pull it off or unscrew? I tried pulling it off just with my fingers but it didn't budge.
Offline brewsky
Re: How to remove tacho needle.
« Reply #1 on: March 20, 2013, 02:34:38 am »
Try 2 teaspoons (protect the faceplate with something)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Nic
« Reply #2 on: March 20, 2013, 03:13:33 am »
So it just pulls off then, thanks, I'll give it a go tomorrow.
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #3 on: March 20, 2013, 03:51:34 am »
Yup.  Use the two spoon meathod.  Put the bottom of the spoons on the screws that hold the faceplate on, the tips of the spoons under the needle as close to the stem as possible, and press down on the end of the spoons.  The needle will pop right off.
Offline kghost
« Reply #4 on: March 20, 2013, 02:04:03 pm »
Well. I've taked about a dozen tachs/speedos apart.
The spoon trick works but I've also broken the drive needle off 2 out of 12.
I use a bit of acetone or MEK on a fine brush to dab it on the shaft where it joins the needle.
Seems to loosen them up on the shaft.
Stranger in a strange land
Offline iron_worker
« Reply #5 on: March 20, 2013, 02:08:23 pm »
I used a screw driver between the cross bar and base of the speedo needle. Seemed a more solid place to pry than the needle itself.
IW
Nic
« Reply #6 on: March 20, 2013, 04:56:42 pm »
Thanks guys, spoon method worked like a charm ;D
