Author Topic: anubis: the '75 cb750a bobber project  (Read 6661 times)
madbunny
« on: July 22, 2006, 10:03:54 PM »
some new pics of the ever continuing project known as anubis.
i installed the 10 degree chrome aftermarket triple trees today to check the fit and the feel of the front end with the cb650 front forks.
i think it'll be fine.
still have to decide if there's some way to marry the 19" spoked wheel to the 650's more modern brakes.
p.s.  found out today:
in a pinch, the oem lower triple tree clamp bolts are the same size as the lower rear shock bolts.
just not chrome.
« Last Edit: April 24, 2008, 04:44:19 AM by crowboy »
Offline Roach Carver
Re: anubis: the '75 cb750a bobber project
« Reply #1 on: July 23, 2006, 07:57:29 AM »
I like it. Is the sparkle tank staying or going?
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: July 23, 2006, 08:33:29 AM »
        crowboy,
                It's quite unusual to see a 750A used in a project. You just might have done a first!
        You've got a cool look going there. I believe you could use a 650 or an early 80's 750 spoke front
        wheel with that front end. My 80' CB750 ha the same basic brake caliper setup. I'm not positive
        though so, maybe somebody will kick in and give some additional info here. I do know that a 650
        wheel will bolt up to a 550 fork but, then I have the same caliper mount issue you do. I'm going
        to swap to 650 fork tube/leg assemblies. Like to have some details on the bike. Pictures are good
        and like I said, you've got a really cool look going there. Keep up the good work and I'll catch you
        later on.      Bill
Member # 1969
ElCheapo
« Reply #3 on: July 23, 2006, 12:09:42 PM »
Ok now I am offended......................... :-\
In case anyone was wondering THIS IS NOT ASSOCIATED WITH ANUBIS CYCLE
« Last Edit: July 23, 2006, 12:12:48 PM by ElCheapo »
madbunny
« Reply #4 on: July 23, 2006, 01:22:41 PM »
no need to be offended, i'm afraid this project (and my use of anubis as a service mark) predates you about three years or so.
Quote from: 71cb750
i'm 50/50 on it right now.
i have a spare K tank laying around, but i'm becoming fond of the peanut, it's height and the way it exposes the frame line.
especially because i'm going to cut the frame in the battery box area and drop that rail about 3-4 inches and put in a solo seat at the height of the original frame line.
i keep tossing back and forth on whether to keep the sparkly gel coat, it's a little cooler in person than it looks.
unfortunately the raked trees dont have any steering stops and when i was tightening the head nut on the steering i put a pea sized chip in the gel all the way down to the white stuff. i dunno.
bill:
do you know whether the 650 spoked front wheel is a 19 incher?
if it is i think that would be the quickest route for me, as i already have the caliper/hoses/switches. i just need a wheel and disc that fits these forks and is at least 19"
i'm also adding floorboards to this project. i'm gonna be pretty wide across the tranny with this bike.
i want this project to be wide and low, like a old hydra-glide bobber.
aside from the horrendous vibration, my biggest complaint with h-d is the bikes are too damned skinny. i don't like getting on a motorcycle and feeling like i've just plopped down on a 60 horse schwinn...
in case anybody is wondering i have no idea who makes the chrome tree. got it from ebay and there's absolutely no identifying marks on it. very heavy all steel part with at least double chrome on it. with the 19 inch tire and the cb650 forks i'm at about 3/4" to maybe 1" of trail so it should still steer fairly neutral.
also, don't use a cheap screw driver as your leverage when tightening the axle down. mine shattered in my hand and cut all the way down to the muscle.
yum.
« Last Edit: July 23, 2006, 01:29:30 PM by crowboy »
Offline bill440cars
« Reply #5 on: July 23, 2006, 01:40:27 PM »
        crowboy, According to my source which is crotchrocket.com , the 80'-82' CB650 has a 19" spoke front wheel. The 79' had a 19" Comstar rim. That should make things easier, provided you can some up with a wheel for a reasonable price. Happy hunting and keep us posted.                                                      Later on, Bill
Member # 1969
Mountainman
« Reply #6 on: July 23, 2006, 09:25:23 PM »
I dig it. Your gonna have to keep us updated on this one.  ;D
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« Reply #7 on: July 24, 2006, 12:35:19 AM »
Keep the sparkles.
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #8 on: July 24, 2006, 06:08:57 AM »
Some clip=on's on that scoo would be sweet...
Those trees make that front-end look killer.  :D
Where'd you get them ?
« Last Edit: July 24, 2006, 09:36:30 AM by ProTeal55 »
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #9 on: July 24, 2006, 08:23:17 AM »
sparkle plenty...keeper...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
madbunny
« Reply #10 on: July 24, 2006, 11:05:38 AM »
i got the trees from ebay, like $35, no markings.
i'm using them with early 80's CB650 forks, the bike is pretty light now and ain't to much goin' back on.
the angle means less action on the forks, so that stiffens them up too.
i don't think i'd use them with longer forks as it looks like the rake would send the trail negative in short order and you'd spend all day trying to hold the wheel upright.
the bike is a cut down '75 K frame with a '76 auto motor, drag pipes and fiberglass peanut tank.
the tank has a metal filler neck that was 'glassed in. the bugger is so tight it requires 2 dry hands and a bit of down force to open. two old brass petcocks, one on each side. and no rust.  ;D
i've got a solo seat from an old riding mower coming from ebay.
roadstar mini floorboards, a completely bleached master cylinder, and some big old longhorn handlebars with fat grips.
yum.
owie.
« Last Edit: April 24, 2008, 04:46:51 AM by crowboy »
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #11 on: July 24, 2006, 12:44:17 PM »
How did you get the photos in the first post to come up fullsize?   ???
The board software normally shrinks images. >:(
madbunny
« Reply #12 on: July 24, 2006, 01:14:37 PM »
yeah?
hella i know.
i do know that the board was being soopa funky when i tried to start this thread.
my browser jus kept loadin' and loadin'
i accidentally posted this thread three times and had to delete two of them.
maybe i hit it during maintenence or sumptin'?
confirmed that the 1981 CB650 front wheel should be a beauty of a match.
i ran across a guy who was selling his '81 and checked out the front spoked wheel, nice and light looking inner spool!
bike seems clean (not super, but reasonable) and his buddy drove it in from garretsville, which is about 45 min from cleveland.
no affiliation with the seller but if anybody wants to get in touch with him i can find out his number.
Sully_PA
« Reply #13 on: October 04, 2007, 07:10:06 PM »
Anymore updates or news on this bike?
  • Moderator
« Reply #14 on: October 04, 2007, 07:24:50 PM »
I've sent him a PM, hope he comes back down here, looks an intresting project.
Sam ;)
Offline bill440cars
« Reply #15 on: October 04, 2007, 09:03:11 PM »
         I hate to say it , but I had forgotten about this one myself. :-[ Sure hope he returns to finish up on it, with pictures of course. ;D 8)
                                  Later on, Bill :) ;)
Member # 1969
Offline tramp
« Reply #16 on: October 07, 2007, 12:12:29 PM »
i have to say i really like the bobber look
but sometimes my wife likes tp go for a ride
guess i have to buy another bike
1974 750k
Offline bill440cars
« Reply #17 on: October 07, 2007, 12:58:35 PM »
       I don't know if anyone else did, but I sent him a PM to see if everything was okay with him and if his wound had healed up okay. I also mentioned that we'd sure like to see more on that Anubis Build. If he responds directly to me, instead of here, I'll let you all know. Hope he's okay and he'll be finishing this one up with pictures.
Member # 1969
madbunny
« Reply #18 on: May 28, 2008, 05:53:41 AM »
hey bill et. al.!
i'm back from the dead (at least that's the excuse i'm claiming for the smell...)
i finally remembered my user name and password.
seriously.
the hand healed well enough, but anubis still waits in the sarcophagus.
'fraid i was broke for a long time and these days i got so much work and family i can barely get to wrenching on the rambler let alone fabrication work. i think i'm going to turn the frame work over to my welding friend just to give him something to do though...
now if i could get the missus to stop working on her stupid '70 triumph bonneville and get to working on my honda.... :P
Offline bill440cars
« Reply #19 on: May 28, 2008, 06:59:28 AM »
       Hey crowboy, good to hear from you and am glad your hand healed up too. That looked nasty. Also glad to hear that things are looking up for you financially and all. ;)
       I've got a 77' 750A myself. It'll probably stay stock for now, I'm just trying to get the time and workspace to get it going. Very interested in what you are doing with that one though. 8) ;)
     BTW, "Good Luck" on getting your missus to work on the Honda! :D
                                    Take care, Bill ;)
Member # 1969
