Author Topic: cb650 cam in a cb550 question  (Read 5349 times)
Offline 2ceebees
« on: March 25, 2013, 12:50:04 PM »
I've looked in the faq etc, but haven't found the answer.  I've got a 75' CB550 and I'm looking for a 650 cam.  What years/models of the 650 cams are correct?
Thanks
1975 CB550K1
and other bikes..
Offline goldarrow
  • one day, i'll be an
Re: cb650 cam in a cb550 question
« Reply #1 on: March 25, 2013, 01:29:12 PM »
Those are nearly unobtainable.  Look for 79-81  sohc 650
CB550 K0
Offline cb650
« Reply #2 on: March 26, 2013, 07:03:03 AM »
and 82 sohc4
Offline 2ceebees
« Reply #3 on: March 26, 2013, 08:12:52 AM »
So 79-82 will work it sounds like.  Yeah, ebay searches are not turning up much.
1975 CB550K1
and other bikes..
« Reply #4 on: March 26, 2013, 08:33:44 AM »
79 was the recommended year as some changes were rumored to have been made on later year model camshaft.
You will see improvements from any of the cb650 sohc camshafts because of increased duration.
Offline cb650
« Reply #5 on: March 26, 2013, 02:08:30 PM »
All the 650 sohc cams are the same.  Except the lopo german cam.   Dought you would get one of them.   79 was a slightly faster bike but it wasnt the cam.
Offline 2ceebees
« Reply #6 on: March 26, 2013, 02:09:32 PM »
"lopo german" cam?    Not sure what that means.
1975 CB550K1
and other bikes..
Offline Bailgang
  • Scott
  • Indiana
« Reply #7 on: March 27, 2013, 02:01:42 AM »
lopo=low performance. I don't know the specifics but from what I understand the 650's sold in Germany at that time had considerably less HP than those exported elsewhere. The cams in the engines sold in Germany had a much milder profile and are not the cam of choice if you're going to swap it into a 550.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline 2ceebees
« Reply #8 on: March 27, 2013, 04:00:04 PM »
Ahh...  good info.  Thanks
1975 CB550K1
and other bikes..
Offline tvs avery
« Reply #9 on: March 28, 2013, 12:04:31 AM »
I found mine by buying a whole cb650 top end on ebay. I got it for next to nothing because no one wanted to pay shipping. I contacted the seller to see if he would just send me the cam, he was more than happy to. He got to sell the other parts and I got a cheap 650 cam with cheap shipping. So I suggest searching for "cb650 engine parts" or "cb650 top end" or "parts bike" as opposed to just the cam. Good luck.
Offline jinx2350
« Reply #10 on: March 28, 2013, 12:15:25 AM »
I found one here from another member, with a cb750 tach. You'll need an appropriate tach as the gearing inside is different on cb550 than 650 and 750.
I don't recall paying too terribly much for both. You should try posting in the wanted section.
'77 CB550 - Dirty Gold, sold in 2014
'79 CB650 - Mostly original, doing a bit of a refresh right now.
instagram: acheatham
Offline 2ceebees
« Reply #11 on: March 28, 2013, 09:10:28 AM »
Thanks for the info folks.  Had a pm from a member who just sold me a 650 cam and tach drive.  Score!
1975 CB550K1
and other bikes..
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #12 on: June 13, 2013, 07:50:59 PM »
I am thinking of doing this too-  with a 77 cb550k
Any chance there is another member here with a cam and a tach drive?
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline xsmooth69x
« Reply #13 on: June 13, 2013, 08:34:02 PM »
going to do this with my bike too.
should i grab extra cams and drive gears?
1975 CB550 (FINISHED?!?!?)
« Reply #14 on: June 14, 2013, 01:33:00 AM »
Cam needed, 550 cam gear used with 650 cam. If you are going with gear driven (cable driven) tach you will need the 650 cam's tach drive gear, or blank off & remove the drive gear and use a later electronic tach.
Offline Lars
« Reply #15 on: June 14, 2013, 06:26:27 AM »
So. What's the gain...? The post from CB 650 indicates it does not give more Power??
...if you got the ability to act...
« Reply #16 on: June 14, 2013, 06:43:29 AM »
Gives more power (torque and hp) through increased duration of the 650 cam when compared to stock cb550 cam. Don't know numbers because no one has done dyno runs for it to my knowledge. It is not huge, but it can be felt as well as seen when riding with stock and modified cb550.
« Last Edit: June 14, 2013, 10:20:06 AM by RAFster122S »
Offline cb650
« Reply #17 on: June 14, 2013, 02:26:46 PM »
Where did I say that?     I've only heard good things about the swap.
« Reply #18 on: June 14, 2013, 04:05:43 PM »
I believe he probably misunderstood your statement about the cams not being different on the CB650 as not being different from the CB550 to CB650...
You indicated other than the German market ones that were a different grind and fairly rare for most of us, the CB650 cams were all the same and any from '79 to '82 fit the CB550.
For the CB550 with a CB650 cam, you will use the CB550 cam chain drive gear and the CB650 tach cable drive gear with a CB650 or CB750 cable driven tach.  The other option is to omit the tach cable drive gear and to use an electronic tach.
David
Offline cb650
« Reply #19 on: June 15, 2013, 03:20:13 AM »
Ok BUT BUT I never said no more power?   No matter I just dont want to be contributed to the " No it cant be done as it wasnt engineered that way" crowd.
 ;D
Offline Bailgang
  • Scott
  • Indiana
« Reply #20 on: June 15, 2013, 03:56:42 AM »
I think you misunderstood cb650's post as well, what he's saying is that all of the sohc 650 cams are the same except for the German cam meaning they will work but try to stay away from one that came from a 650 that was exported to Germany because those are different. It will still run with the German cam but you wont get the performance boost you're wanting because the German cam has a milder profile compared to the other 650 cams. 650 cams are getting harder and harder to find because this is a very popular performance mod for 500/550 owners and people who are parting out a sohc 650 know this and 500/550 owners wouldn't be doing this swap if there wasn't any performance to be gained.
I don't have side by side dyno numbers to prove it but I can tell you that from my own experience you will definitely feel the increase in power when swapping out the stock 500/550 cam with the 650 cam.
Scott
71 cb350 twin
77 cb750 F2
Offline 2ceebees
« Reply #21 on: June 24, 2013, 05:01:11 PM »
What I'm looking for more info on now is what other changes make sense when upgrading the cam.  Will it be a reason to change the jetting?
1975 CB550K1
and other bikes..
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #22 on: June 24, 2013, 05:37:56 PM »
Keep your eyes open for a 650 parts bike with the motor intact.  I found mine here in NC for 125.00, scavenged the cam and tach drive, sold the header for 100.00 and still have the rest of the bike left.  I also pulled other parts to use in my 550 build like that nice alloy points cover which polished up nice instead of my rusty 550 chrome one.  All around it was a good way to go.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
