Author Topic: Prepping and painting the tank  (Read 5295 times)
Offline nccb
  • 1974 CB750 Four
Re: Prepping and painting the tank
« Reply #25 on: April 22, 2013, 07:01:03 AM »
Nice color, almost looks like freedom green.  Is it an acura color? I can't read the label.
Offline zenocchio
« Reply #26 on: April 22, 2013, 07:16:04 AM »
It's British racing green, jaguar
Offline Magilla
  • My bike: 1976 CB750F
« Reply #27 on: April 22, 2013, 08:37:16 AM »
my 2 cents on the Bondo thing.
You are not so much covering the entire tank in Bondo as you are skim coating it.  I say skim coat because you are not putting it on thick.  A very thin layer and then block sand it with a flexible block.  NEVER USE YOUR FINGERS WITHOUT A RUBBER BLOCK.
Once you sand it down there will only be a few tiny spots that still have any Bondo in them.  They are your low spots.  Circle them with a sharpie and then skim coat it again.  Then sand it again.  As you sand away the bondo the sharpie circle will show up.  Do you have any spots without circles?  Those are the ones that you missed with your first attempt.
Primer;  A filler or etching primer works good for me.  Lay on a few coats and wet sand it smooth like glass.  Use a squeegee to look for low spots.  They will be darker than the rest of the tank.  If you have any small low spots you will need to prime and sand again.
All of this takes time.  Days in fact.  The end result will be worth it.
The more time you spend on your paint, the more time you will spend enjoying it.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #28 on: April 22, 2013, 03:13:45 PM »
Use a good quality epoxy primer , it does all that with less sanding.... ;)  You will still need filler in the dings of course... ;)
