Author Topic: Transmission work  (Read 1201 times)
Transmission work
« on: March 28, 2013, 03:58:17 AM »
Just to verify my assumptions:  to do transmission work, like to deal with worn out dogs, I have to take the head, cylidners, pistons, crankshaft off - basically the whole engine apart, correct?
Online dave500
Re: Transmission work
« Reply #1 on: March 28, 2013, 04:07:55 AM »
mostly yes,you can invert the engine and pull the bottom off somewhat on500/550s.
« Reply #2 on: March 28, 2013, 05:04:50 AM »
Thank you,  I figured you can't get around the chain from crankshaft to the transmission.
My #2 gear is geting out of control, will need to do something about it.
I never had SOHC engine bottom apart, hence my dumb questions.
Online dave500
« Reply #3 on: March 28, 2013, 05:14:50 AM »
someone will chime in here,on 500/550 you can drive the primary shaft through and split the cases leaving the top end intact,im not familiar with the 750.
« Reply #4 on: March 28, 2013, 05:16:13 AM »
On your 750 you should be able to service/replace the tranny without taking the top end apart.
« Reply #5 on: March 28, 2013, 05:29:09 AM »
Thank you  :)
If there is a way, I will just pull the engine, flip it over and start taking it apart - and get there eventually.
Thanks!
« Reply #6 on: March 28, 2013, 05:33:41 AM »
Take good pictures or make a little diagram of the shift linkage parts behind the sidecover when you disasemble. That was a major head scratcher for me once back in the day before the internet to get it back together   ;)
« Reply #7 on: March 28, 2013, 05:54:33 AM »
Maybe it's time you buy one, Dave?! Or, you don't want to change your forum name?
Offline andrewk
  • doin' it.
« Reply #8 on: March 28, 2013, 06:40:27 AM »
You can service the transmission without taking the top end apart.  Not the worst thing in the world- you can even do the primary chain while you're there if you don't mind taking the rods apart.  When you split the cases, make sure you keep track of the bearing retainer pieces, as well as the alignment dowel pins.
« Reply #9 on: March 28, 2013, 09:02:06 AM »
I found this thread:
http://forums.sohc4.net/index.php?topic=59158.0
exactly what I am gonna do.
There is no better place than the SOHC4  ;D
Offline lucky
« Reply #10 on: March 28, 2013, 11:29:26 AM »
Keep track of EVERY part!- Lucky
« Reply #11 on: March 28, 2013, 07:14:43 PM »
Make sure the snap-rings are re-assembled in the proper orientation.
