Author Topic: Headlight diameter?  (Read 3263 times)
Offline The other Derek
  • Merely an
Headlight diameter?
« on: March 31, 2013, 09:45:28 PM »
Been chipping away at my CB750k6.  I ordered a replacement chrome ring and H4 light and both are ~8" in diameter.  My bucket is ~7".   Should I be b!tching to the seller or do I have the wrong bucket?
My bucket is marked HM-16M on the back.
Offline Dimitri13
  • 1974 CB550K
Re: Headlight diameter?
« Reply #1 on: March 31, 2013, 10:20:08 PM »
Stock headlight is 7".
« Reply #2 on: March 31, 2013, 10:20:17 PM »
7 should be standard,you sure hes selling you an 8 inch?
« Reply #3 on: March 31, 2013, 10:58:11 PM »
The glass part of the light will measure 7". The ring and the shell opening will measure more, though still known as a 7".  Because they fit 7" lens.
OCICBW
  • Merely an
« Reply #4 on: April 01, 2013, 05:15:52 AM »
The new ring is ~1" larger than my bucket and the new bulb assembly fits the ring perfectly.  It was sold as a replacement for a SOHC cb750.
Just gotta hear back from the seller now.
Thanks guys.
« Reply #5 on: April 01, 2013, 05:32:11 AM »
Thanks guys.
oops.  :(
  • Merely an
Re: Headlight diameter? (What bike does this bucket go to)
« Reply #6 on: April 04, 2013, 05:03:51 PM »
I appreciate the responses, but I don't think I asked the right question.  I'm relatively certain that this isn't a headlight from a CB750 and that I need a new bucket instead of returning the other parts.
Is this off a 360?
Here's my headlight:
At this point I think I'd prefer to just pick up a replacement.  My rattle can paint job is going to look like a$$.
« Reply #7 on: April 04, 2013, 05:47:16 PM »
Yeah that bucket looks weird. Close to CB750 but kinda warped. Stretched front to back.  And the hole at 12: o clock?
Offline Dream750
« Reply #8 on: April 04, 2013, 06:14:39 PM »
A stock 750 K6 headlight bucket should be marked: HM-20M
Honda part number: 61301-300-020B
Used on 750 K2 thru K6 and other SOHC models.
  • Merely an
« Reply #9 on: April 04, 2013, 07:21:48 PM »
The hole was from a switch to shut off the headlight that the PO installed.  The original start switch had been replaced with a push button mounted between the gauges and the usual mess in the headlight bucket was made worse by all the extra stuff going on.  Hoping to get to that soon.
Thanks again, guys.
