Author Topic: Inconsistent neutral light?  (Read 1408 times)
Offline gregripko
« on: April 04, 2013, 09:09:33 AM »
Cb550K 76 - lately my neutral works about 95% of the time but I'm finding that sometimes the bike will be in neutral but there's no light.... Any recommendations?
Offline Mo
Re: Inconsistent neutral light?
« Reply #1 on: April 04, 2013, 09:20:09 AM »
try cleaning the switch under the left side engine case. Mine would do the same thing, and then once I cleaned the switch, ti worked like a dream.
Offline gregripko
« Reply #2 on: April 04, 2013, 09:39:01 AM »
Figured that was the case.... Replacing a seal today so ill have a look... Don't know what it looks like
« Reply #3 on: April 04, 2013, 09:49:03 AM »
Neutral switch and also where it fits on the engine.
Offline gregripko
« Reply #4 on: April 04, 2013, 10:02:56 AM »
Awesome! Ty :)
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=r6ajbr84hlvica01bdj21u1o22&/topic,60973.0.html
« Reply #5 on: April 04, 2013, 11:46:15 AM »
on a 550 it looks like this..up in the top behind the yellov flex vire
klik on photo to get it bigger
« Last Edit: April 04, 2013, 11:48:33 AM by strynboen »
i hate all this v-w.... vords
Offline gregripko
« Reply #6 on: April 04, 2013, 12:20:45 PM »
Do I have to pull it out to clean it?
« Reply #7 on: April 04, 2013, 12:22:05 PM »
Oops, I am sorry, always asume everybody has 750.  :)
That is one clean engine you got there!
Offline iron_worker
« Reply #8 on: April 04, 2013, 12:28:18 PM »
Yes you'll have to pull it out. There is a little steel ball with a spring behind (like a check valve sorta) it that gets depressed when the bike is in or out of neutral. Probably some junk got in there and it's sticking.
IW
« Reply #9 on: April 04, 2013, 12:41:32 PM »
The ball & spring is the neutral locator for the earlier CB500,  the 550's use a different mechanism. Just unplug the single neutral switch wire and cleanup the area. As mentioned that should solve your problem.
Offline 750K
« Reply #10 on: April 04, 2013, 02:50:09 PM »
If that doesn't work, check the bulb in the indicator itself. I just had to swap out the bulb for my high beam indicator, the filiment had broken and would touch 50% of the time.
77 Cb750, 78 Kz1000
Offline gregripko
« Reply #11 on: April 04, 2013, 04:50:17 PM »
Cleaned up the area and it seems like it's working effectively...
