Author Topic: When it rains....  (Read 16770 times)
Offline Xnavylfr
Re: When it rains....
« Reply #75 on: August 10, 2013, 10:17:26 AM »
What I was saying , MOST on here think your bike has to have stock airbox , stock carbs , stock forks, stock gauges, you get the idea.
Yes I can agree SOME CB750s in ORIGINAL condition are worth serious money but the percentage of them have had so many parts replaced on them since 1969, that the ONLY thing original is the frame and even that, if it has had upgrades added,ie,frame rail kits and roller bearings in the neck, then it is no longer original only improved.
I know you can tune carbs for the type of air filters and exhaust, but it is sometimes trial and error.  Most newbies don't understand , if you change exhaust( more air OUT) then you need to change carb jets for more air/fuel in!!
Oh by the way Inkscars: glad you got your bike in tune!!
Xnavylfr(CHUCK)
Offline Inkscars
  • grumpiness comparable to an
« Reply #76 on: August 10, 2013, 03:30:47 PM »
It's not impossible to do. Most people do not have the patience for it.
4 carburetors on a bike is like a puzzle, and I'm hard headed as #$%*.
So, trial, error and piece by piece, my bike runs pretty great and while I will agree to a degree that it might have been easier with a stock set up, my air box was garbage to begin with so I worked with what I had.
I love the way it looks and that I had to put work into it.
Two words, worth it.
81 Hardly Davisson
Offline Xnavylfr
« Reply #77 on: August 10, 2013, 04:10:35 PM »
You are a lot like me then!! you make due as needed to get her going, and IF someone says they don't like the way it looks , then tough S%$T, I built MY bikes the way I want them to look and if someone says they don' like it ,that's THEIR problem not mine!!
Xnavylfr(CHUCK)
Offline Eydugstr
« Reply #78 on: August 11, 2013, 09:23:07 AM »
Congrats on getting the bike sorted out, Inkscars!  Also, TY for posting all the info of what you did to sort it out.
Offline Inkscars
« Reply #79 on: August 11, 2013, 09:54:52 AM »
Thanks! And you're welcome! Obviously if I can help someone get to where they need to be, I should.
81 Hardly Davisson
« Reply #80 on: August 11, 2013, 10:44:12 AM »
Inks ..best advice on the ironhead..go through it.. Everything iffy that you reuse, could probably come back to bite you... Did you see the unworldly one Powderman has ?
Offline Inkscars
« Reply #81 on: August 11, 2013, 03:39:55 PM »
The fella that helped me with Elsa this round is a Harley guy. I've spent most of the last year learning about the iron head. He rode his shovel to sturgis, the 1 thing he decided to reuse(regulator) went out 90 miles from sturgis, so.....it'll be expensive, but the #$%* will be new.
81 Hardly Davisson
« Reply #82 on: August 12, 2013, 04:11:20 PM »
Inkscars, thought you might enjoy this...
http://www.brewracingframes.com/id67.htm
« Reply #83 on: August 12, 2013, 04:24:51 PM »
That kinda looks like Amber
Offline Xnavylfr
« Reply #84 on: August 12, 2013, 06:40:44 PM »
You might like these also, they'll build to order!!
http://cycleonemanufacturing.com/harleydavidsonbigtwincustommotorcycleframes.html
Xnavylfr(CHUCK)
Offline lucky
« Reply #85 on: August 13, 2013, 03:07:53 PM »
You are not going to escape removing those carbs and finding out what size idle jets you have.
And while you have the carbs off make sure that all 4 mixture screws have O rings in good condition and each one has a washer on top of that O ring.
Then make sure all 4 of the accelerator pump spray nozzles are functioning properly.
If you want to keep the pods then get the #42 idle jets.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #86 on: August 13, 2013, 04:24:00 PM »
i had a older mechanic tell me the secret to pod filters is to make sure that the tiny openings in front throat of carbs ( may have brass orifice in them) are un restricted by the pod itself.  some trimming  may be required so they are clear.  and of course a refernce mark somewhere on lip of pod to line them up upon reinstall.  that little hiccup in video could be little bit of carbon making a valve stick slightly if its an old motor.  try seafoam in oil and gas.  hope this helped.
MATT
Offline Inkscars
« Reply #87 on: August 13, 2013, 07:19:51 PM »
It was the resistor/spark plug boot on #4, but your info for the pod install is helpful for someone who could overlook such a thing!
81 Hardly Davisson
« Reply #88 on: August 13, 2013, 07:37:51 PM »
Imagine having 4 tits on a bike, then add 2, and that's mine haha
You talk about tits, then post a picture of riding gear on the hood of a car!??  >:(   ;)
Offline Inkscars
« Reply #89 on: August 13, 2013, 07:40:19 PM »
Well I'm certainly not gonna post pictures of my own tits. Not all of them anyway....
81 Hardly Davisson
« Reply #90 on: August 13, 2013, 07:42:59 PM »
OOOh, i can see your pussy too.... ;D :o....sorry.... :P
« Reply #91 on: August 13, 2013, 07:44:54 PM »
Two appears to be quite adequate; I don't need to see the other four. ;D
Offline Inkscars
« Reply #92 on: August 13, 2013, 07:48:48 PM »
That's Internet phenom "lil bub"!!!
81 Hardly Davisson
Offline Inkscars
« Reply #93 on: August 13, 2013, 07:50:00 PM »
You sure? I'm pretty sure I've got a picture of those little bastards somewhere
81 Hardly Davisson
« Reply #94 on: August 13, 2013, 07:53:32 PM »
Pics or you don't have em
Offline Tews19
  • I am no
« Reply #95 on: August 13, 2013, 07:54:38 PM »
WOW! Can I join the party?
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
« Reply #96 on: August 13, 2013, 08:01:23 PM »
In all seriousness.... I see a helmet... Jacket.... Gloves... and a tool belt? What's the belt for?
« Reply #97 on: August 13, 2013, 08:04:19 PM »
For the extra boobies?
Offline Inkscars
« Reply #98 on: August 13, 2013, 08:07:06 PM »
As a female rider with the kind of bare bones bike I ride, I had to get creative on how to get #$%* I need on the bike with me and not wear a back pack.
It's a military grade utility belt (for grenades and ammo and canteen and stuff) that I modified a purse to fit onto so I wear it as a belt.
I can fit all the stuff a girl could need in it and not have to worry about a shoulder bag, back pack or purse.
81 Hardly Davisson
« Reply #99 on: August 13, 2013, 08:09:24 PM »
Lie the bat (girl) belt!
