Author Topic: Spoked wheels for my cb with 2008 GSXR front end?  (Read 10499 times)
Offline thipps
  • If you cant build it......Design it
    • hippsdesign
« on: April 06, 2013, 06:43:26 PM »
Hey guys I just got a 2008 GSXR front end for my 73 CB500, I have read a couple threads about machining hubs to make them work with the dual disks for the Gixxer front end. Im wondering if anyone sells a ready fit hub for this application or a entire wheel? If not is there someone here that could handle that?
Thanks guys I cant wait to start posting some pictures of the build
« Last Edit: April 06, 2013, 06:56:18 PM by thipps »
Offline Tews19
  • I am no
Re: Spoked wheels for my cb with 2008 GSXR front end?
« Reply #1 on: June 15, 2013, 11:20:16 AM »
How much you get it for if you don't mind
1970 Honda CB750 survivor.
Offline jojo
« Reply #2 on: August 22, 2013, 11:29:43 AM »
I know there is a guy on the dotheton website that sells them. He has a few of them laying around since he had to buy 10 or so in order for the shop to build his. Name is speedbump. give him a shout.
Offline Elan
    • Vital Motor Parts
« Reply #3 on: August 22, 2013, 12:18:39 PM »
harley narrow glide wheels can be had for under $150 used if you keep an eye on ebay. you will need 2 spacers for the axle. Theres more details around the forum..
76 750k
Offline nixon
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
Offline SecondShift
« Reply #5 on: April 09, 2015, 02:03:09 PM »
Old thread, I know, but since GSXR swaps are still happening, I'm throwing this out there. A factory Honda front disc brake hub will work with a GSXR front end. Hub is from a 1976 CB750. Rotors can be done a few different ways, this is set up with '99 CBR900RR rotors.
« Reply #6 on: April 09, 2015, 03:05:07 PM »
Devin at cognito moto is your guy, he makes everything bolt on for these swaps, including the correct offset triple clamps....
http://cognitomoto.com/collections/fork-conversion-parts
Offline knottedknickers
« Reply #7 on: March 16, 2016, 07:24:43 AM »
Hey SecondShift,
Not sure if you're still around here, but could you provide a few more details about this setup? Can you use the original speedo drive with this setup?
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
Offline sinister902
    • Anger Street Kustoms
« Reply #8 on: March 16, 2016, 12:26:55 PM »
Hey SecondShift,
usually no. it takes a bit of work to use a stock speedo. I just did one over the past few days to retain stock speedo but it's quite a bit of work on the lathe and mill to make a multi-piece spacers setup to relocate the speedo driver while also still having it function.
https://www.instagram.com/p/BDBBWQqg28A/?taken-by=angerstreetkustoms
on top of all the time and labor into making custom axle adapters, rotor spacers/adapters need to be made to get the rotors centered into the calipers, and triple trees need to be made for proper offset/trail. Pretty easy to spend about $500-600 in materials and then all the machining, which is why cognito moto makes what he does for what it costs.
