Author Topic: Re-Use spokes from Goldwing Rear wheel?  (Read 1100 times)
Offline singedebile
« on: April 06, 2013, 08:16:54 PM »
Getting around to lacing up my rear wheel to my 550 hub and the spokes are in good shape on the GoldWing wheel. Can I re-use them? I am curious because I noticed the flange is slightly different on the hubs. If I can I would really rather save the money, especially as if I buy new spokes for the rear the front will then look out of place.
Anyone done this before? just re-used the spokes on their GoldWing Rim swap?
Thanks,
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline Harsh
  • 74 CB750 and two 72 CB350's
Re: Re-Use spokes from Goldwing Rear wheel?
« Reply #1 on: April 07, 2013, 09:22:48 AM »
I would say that if the spokes are in good condition then re-use them.  Lace it up and check to make sure the difference in the flanges doesn't bend them too much.  If that is good then there you have it.  A buddy of mine is using my old GL spokes on his custom 82 Virago build with a Harley wheel.
« Last Edit: April 07, 2013, 09:28:23 AM by Harsh »
Offline BPellerine
« Reply #2 on: April 07, 2013, 10:07:54 AM »
I also reused my gl spokes along with the washers or spacers if you want to call them that , seem to be reinforce the spoke nipples on alloy rim ,not sure I know they are not on the steel rims works well.bill
1978 CB 750K ard and webers
another anfob
Offline singedebile
« Reply #3 on: April 08, 2013, 12:18:13 AM »
Thanks! for the help, I'lll give it a go!
Offline BPellerine
« Reply #4 on: April 08, 2013, 05:49:36 PM »
Good luck ! worked for me. bill
another anfob
Offline lone*X
« Reply #5 on: April 08, 2013, 06:59:17 PM »
check this old thread.  Reply #186.
http://forums.sohc4.net/index.php?topic=1590.175
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
