Author Topic: Motul with new rings?  (Read 1458 times)
Offline ealanm
« on: April 07, 2013, 06:20:42 pm »
I'm using a mostly stock CB750 as a race engine.  I've been running Motul 5100 10W40 in the engine for several seasons, with good results.  I'm reassembling it now with new rings and a light cylinder honing.  I've had problems in another kind of race engine trying to seat rings with semi-synthetic oil.  Should I run the engine initially with something else, for ring seating, or will Motul get the job done?
"Speed, it seems to me, provides the one genuinely modern pleasure."
--Aldous Huxley
Re: Motul with new rings?
« Reply #1 on: April 07, 2013, 06:34:32 pm »
Standard oil for break in.
Offline Jim F
  • go baby go
« Reply #2 on: April 09, 2013, 11:40:05 am »
I second the motion when it comes to breaking in new rings
use a good petroleum base oil to start with
I am using Brad Penn oil in my new turbo motor
and will continue to use it because its a good oil for plain bearing turbos
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline BLUE71TURBO
« Reply #3 on: April 09, 2013, 01:43:53 pm »
When it comes to oil, if not synthetic or an off road/ racing oil, most blends have had the zinc phosphate taken out because of the damage it does to catalytic converters. So buy and additive or use and oil that has the zinc added to it. It's to help older engines that have flat tappet cams and no smog ( converters ).  Search " ZINC " in motor oils.   ;)
Offline turboguzzi
« Reply #4 on: April 09, 2013, 02:38:47 pm »
udo gietl used to assemble his race engines dry to ensure ring seat
its on those very first seconds till oil gets to them that the honing acts as fine sand paper and makes the rings fit the bore.
and dont baby the motor either
« Reply #5 on: April 09, 2013, 06:28:56 pm »
I've done the same for a while now. I still don't like synthetic for first start up.
