Author Topic: Is the thickness of an O-RING typically oversized?  (Read 548 times)
Offline Stoli
« on: April 10, 2013, 11:04:23 AM »
If I check the thickness of a new O-RING that is supposedly 18x3, should it measure exactly 3mm or do they typically oversize them a little? I just took one out of the package and it measures a solid 3.5mm before it starts to compress.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline brooze72
Re: Is the thickness of an O-RING typically oversized?
« Reply #1 on: April 10, 2013, 11:10:23 AM »
My understanding of "O"Rings is no, they shouldn't be over/undersized on the thickness or the ID or OD will be off spec.
1972 CB500K1 - restored rider
1981 CB650C - new project
Online RAFster122s
« Reply #2 on: April 10, 2013, 11:17:23 AM »
+1 to what Brooze said
Hondaman had some comments about rebuild/gaskets and their Orings a while back...
gist was most were too large...
Offline Stoli
« Reply #3 on: April 10, 2013, 11:34:21 AM »
Hmmm. Interesting...
I have a couple of brand new Honda rings which are listed as 18x3 (part# 91307-030-000) and the width of the ring portion measures exactly 3mm but the height measures 3.5mm and I believe it is enough to keep my neutral switch from seating properly.
My Project Threads:
Offline Stoli
« Reply #4 on: April 10, 2013, 12:24:46 PM »
Refer to new thread for a more applicable discussion on this issue:
http://forums.sohc4.net/index.php?topic=120094.0
My Project Threads:
