Author Topic: Where does this washer go?  (Read 761 times)
Offline Kinch
« on: April 10, 2013, 03:55:37 PM »
Hi all, please assist. I am in the process of a complete rebuild on my stock CB750 K5.
I cracked the cases but did not disassemble any of the shafts. I resealed the cases, reassembled the whole engine (using the Honda manual and Hondaman's book), re-attached the shift linkage, clutch and alternator. All seems good but after all that I am left with this washer and I can't figure out where it goes....which is obviously very worrying.
Any advice would be appreciated.
1975 CB750 K5
1980 GS850L
Re: Where does this washer go?
« Reply #1 on: April 10, 2013, 04:01:36 PM »
Looks like an oil plug/drain plug sealing washer. From the oil pan or tank?
Offline Kinch
« Reply #2 on: April 10, 2013, 04:14:42 PM »
Yes, I think you're correct. Thanks MCRider, I was bricking it a bit.
1975 CB750 K5
1980 GS850L
Offline Vinhead1957
« Reply #3 on: April 10, 2013, 04:49:24 PM »
Don't forget the spring
« Reply #4 on: April 10, 2013, 04:51:52 PM »
I think your thinking of the washer and spring in the oil filter cover. That washer is larger ID and very thin.
If I'm right, the washer in question goes on a drain plug. No spring.
Offline Kinch
« Reply #5 on: April 10, 2013, 05:14:18 PM »
Drain plug is correct, thanks again.
1975 CB750 K5
1980 GS850L
« Reply #6 on: April 10, 2013, 09:05:57 PM »
Hey Kinch, seeing as how you are in San Diego, you might be interested in a ride we have coming up soon. ;D Read more here:
http://forums.sohc4.net/index.php?topic=118076.100
