Author Topic: cb 550 leaks  (Read 1171 times)
Offline phil71
cb 550 leaks
« on: April 11, 2013, 10:19:43 PM »
I just replaced every gasket above the cases. Previously, the bike bled like it was in a knife fight. Now, i've got some dripping from the left cam cover. I know it's the crush washer on the downward facing bolt that holds the bracket for the cam cover.. the thing is, the fiche is very vague. Are both washers crush washers, or just the lower?
  Also, it seems like it is still be weeping from the left oil gallery, where the o-ring is, but I was METICULOUS in it's reassembly, even retorqued head bolts after running awhile. The castings looked good, mating surfaces were f'n SPOTLESS.. so I don't know why this would be .
  The thing that's most troubling is, that the side that still leaks, while slowly, is the same place where it leaked the worst before I went thru this. Any experiences you can share would be appreciated. If i gotta take it apart again, I'd love some tips before I do.
Thanks!
Offline goldarrow
  • one day, i'll be an
Re: cb 550 leaks
« Reply #1 on: April 12, 2013, 12:35:16 AM »
Try different oring size on the side cam covers.  That did the trick for me.
CB550 K0
Re: cb 550 leaks
« Reply #2 on: April 12, 2013, 12:48:07 AM »
put a copper one top and bottom,make sure the angle bracket isnt burred and is square.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: cb 550 leaks
« Reply #3 on: April 12, 2013, 10:01:59 AM »
Head gasket weep: Use copper gasket spray the next time you replace the head gasket. Worked for me. I used the OEM o-rings.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline phil71
Re: cb 550 leaks
« Reply #4 on: April 12, 2013, 09:00:44 PM »
Ok.. Duane, that's good advice. now i think i have a different problem. The cam tower leak is sussed out. There's a bigger problem. If you look at this picture, you'll see the leak. It actually appears to be leaking ABOVE the gasket surface.
  At first glance, I thought it was the front loop in the head gasket, but I don't believe there's any oil under pressure there.
    I hadn't given it much thought before, but there's one bolt in the exhaust where the rest are studs. Is it possible whatever event got the stud snapped or drilled out hit an artery? There's oil ON the exhaust bolt, and then it's pooling below. The rate of leak makes me think it's a return rather than a pressure feed.
Any ideas?
Re: cb 550 leaks
« Reply #5 on: April 12, 2013, 09:07:11 PM »
that point you show in the pic is only splashed heavily with oil,its not under any real pressure,those front and rear 6mm bolts on these should only be nipped down with a strangled short wrench,never torqued as per specs!oil leaks on bikes can be hard to pin point with all the wind blowing every which way around,none of the exhaust studs go into oil pressure,one tip though,,i use a little hardening type compound on those peaks on the head gasket that are crushed down by those two 6mm bolts front and rear that should only be hand tightened.
« Last Edit: April 12, 2013, 09:10:47 PM by dave500 »
Re: cb 550 leaks
« Reply #6 on: April 13, 2013, 07:20:44 AM »
Did you put new rubber pucks, with sealant on the edge, between the cam cover and head?
Offline phil71
Re: cb 550 leaks
« Reply #7 on: April 13, 2013, 10:28:26 AM »
Wait, no.. the kit didn't come with it.
Re: cb 550 leaks
« Reply #8 on: April 13, 2013, 10:41:25 AM »
Theres your leak then mate
Offline phil71
Re: cb 550 leaks
« Reply #9 on: April 13, 2013, 04:36:33 PM »
sonofa... you're right. Thanks everyone!
