Author Topic: CB550 Horn issue  (Read 1003 times)
Offline Untold
CB550 Horn issue
« on: April 13, 2013, 10:27:37 AM »
So my horn seems to cut in and out. I'll be riding, and the horn will work just fine.  Other times, I'll hit the button and get nothing.   I can hear it click, and the headlight will dim to pretty much nothing, but no horn sound.  If I take the horn off and touch the leads directly to a battery, it beeps. Tried two different horns, and eventually the same thing happens with both.  Battery has a good charge.
I've cleaned all the connections and inside the switch. Checked for exposed wiring.  still nothing.
What else can I check?
1976 CB550K
Re: CB550 Horn issue
« Reply #1 on: April 13, 2013, 10:42:28 AM »
depends on your wiring as there are two types
Offline Untold
« Reply #2 on: April 13, 2013, 10:59:34 AM »
Just tried touching the light green wire to the frame, and the horn sounds. So the problem has something to do with the light green wire not getting grounded by the horn button.
1976 CB550K
Offline Untold
« Reply #3 on: April 13, 2013, 01:21:16 PM »
Ok, I guess I didn't clean the switch as well as I thought. Went at it with a wire brush and now the horn is working.
1976 CB550K
