Author Topic: damaged cooling fins  (Read 935 times)
Offline ianmck
  • 400/4 cb750k4
« on: April 13, 2013, 12:08:31 PM »
I have got a couple of slight chips on three of the engine cooling fins, does anybody have any good ways of repairing them, the engine is out but I dont want to strip it if possible.
1977 400/4 supersport,  1973 CB750 K4
Offline Bob Wessner
  • "Carbs Suck!"
Re: damaged cooling fins
« Reply #1 on: April 13, 2013, 12:44:11 PM »
I used an epoxy clay to replace a chunk out of the very top fin on my 750. That was about 6 years ago and it's still there, no problems.
bollingball
« Reply #2 on: April 13, 2013, 12:53:54 PM »
Bob I know it has been a long time but do you recall the brand name? Is it the kind with two colors you knead together?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: April 13, 2013, 01:01:45 PM »
I do recall that. it was a method to let you know you had kneaded the parts together uniformly. Wish I could recall the specific product, sorry.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: April 13, 2013, 02:02:05 PM »
I thought this had come up before and did some searching, here is the product I used and the thread.
http://forums.sohc4.net/index.php?topic=19402.msg202306#msg202306
Offline kghost
« Reply #5 on: April 13, 2013, 02:12:59 PM »
Use a 4043 rod and TIG weld them back up
Stranger in a strange land
Offline lucky
« Reply #6 on: April 13, 2013, 10:03:12 PM »
KGOHST is right.
 It is the best method.  Not for a beginner though.
« Reply #7 on: April 13, 2013, 11:00:26 PM »
I have a welder shop here who regularly "draws" them back onto engines I get with broken and missing fins. It is just elbow grease with a file to shape them to match the others afterward.
Offline jamesb
« Reply #8 on: April 14, 2013, 06:25:42 AM »
If they are not to bad just file them down. My 750 engine had some broken fins. I spent about 2 1/2 hours and filed them down. It's been awhile now and I can't tell where they are at.  You can blend them in pretty good
Offline ianmck
  • 400/4 cb750k4
« Reply #9 on: April 14, 2013, 12:24:35 PM »
Thanks for all you help, much appreciated, Ian.
