Author Topic: 125-75 or CX-7  (Read 4878 times)
Offline CrazyRocketMan
Re: 125-75 or CX-7
« Reply #25 on: April 16, 2013, 09:50:02 PM »
You could have some goes on mine Sam,
Maybe a Drag guy like you could help me convince some others that Aluminum is not so bad..  ;)
While we are at it. Mike Rieck ever been to CO?? He and Bruce would have a blast with motor talk.
One of my buddies was one of the founding investors for HPR and now the treasurer. I could call tomorrow and find out what the Schedule looks like.
Hmm. Perhaps this should be moved to a new thread? Have a SOHC4.net meet at HPR? Is there interest? I'll volunteer for some planning duties.
Re: 125-75 or CX-7
« Reply #26 on: April 16, 2013, 10:02:29 PM »
OK.. So track info and schedule are online at:
www.highplainsraceway.com
Offline Bill/BentON Racing
    • BentON Racing
Re: 125-75 or CX-7
« Reply #27 on: April 17, 2013, 06:07:16 PM »
Bill,
Very clever name, I dig it!
Thanks for the input on the 125/75. That cam sounds perfect! I cant wait. So close to assembly time its killing me..K. First time you hit the powerband with your 125/75 , you'll be Oh hell yes!! Trust me!Bill
BentON Racing Website
BentON Racing Facebook
Offline Turbogrimace
    • Draft Cycle Works
Re: 125-75 or CX-7
« Reply #28 on: April 24, 2013, 07:59:23 AM »
FYI, I posted this on another thread referencing this cam, but thought it would be good over here too.
I just had a chat with Ken.  He said that the cam is identical to the -75 megacycle but has 3* more duration on intake AND exhaust.... A changed that slight can be deleted by running the tappets a little looser.  His explanation was that it was an extra 1.5* on either end of the lobe, which would put the intake on the CX-7 opening at 27.5* BTC and closing at 57.5* ABC.   Exhaust would be open at 54.5* BBC and closed at 25.5 ATC.  Lobe centers 105 int and 104.5 exh.  Overlap, closed dur., etc can be tinkered with a bit with the tappets.  the CX-7 is basically identical to the 125-75.
Cam Specs   Valve Lift      Duration @.04   Int. Open   Int. Close   Exh. Open   Exh. Close   Lobe Center   Overlap   tappet Clearance
                    Int.   Exh.   Int.   Exh.   BTC   ABC   BBC   ATC   Int.   Exh.   Calc.   Int.   Exh.
Megacycle 125-75   0.400   0.375   262    257    26   56   53   24   105   104.5   50   0.005   0.005
CycleX CX-7   0.400   0.375   265    260    27.5   57.5   54.5   25.5   105   104.5   53   0.004   0.004
