Author Topic: Yes, a Z1 & H1- unofficial Kawasaki thread - H2 is now a rider!!!  (Read 244798 times)
Offline grcamna2
Re: Yes, a Z1 & H1- unofficial Kawasaki thread - Now H2 assembly!
« Reply #1225 on: July 11, 2017, 12:09:03 PM »
it would be interesting to try to ride behind that H1+4 when he gets on it  8)
Funny thing was, it didn't sound that outrageous. I was wondering what kind of firing order it had. Maybe a couple of cylinders fired in pairs
Put the front wheel up against a brick wall and see what kind of 'smoke show' it would give you.  :D
« Reply #1226 on: July 11, 2017, 03:15:56 PM »
If you look closely, it is not a "double Triple", it is a "Seven".
Holy #$%*e, it sure is.  WOW!!
« Reply #1227 on: July 12, 2017, 05:57:28 AM »
Wonder what size those cylinders are or engine its based off. It says 606 so maybe 250 pots ?? Cool stuff.  If 7 is good than 48 must be even better !!  ;D
« Last Edit: July 12, 2017, 06:07:33 AM by ekpent »
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #1228 on: July 12, 2017, 06:11:21 AM »
I missed to ask Rick. 250 is probably right on, although the 249cc Triple would not make quite 606cc. Maybe the pots were slightly bored.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #1229 on: August 04, 2017, 05:01:23 PM »
Been busy with The K4 "Big Bang" engine rebuild, but that motor is back in the frame so I am back to the H2!
[I hate doing multiple projects at the same time but somehow it always happens...maybe I have A.D.D.?!!]
Got the coils cleaned up and installed. Yes, Mitsubishi is the OEM coil, 1 for each cylinder.
Battery box with the [stock] CDI and voltage regulator cleaned up nice. Got it and wiring harness installed....
Broke the bolt on the rear brake cam lever, it was not even in all the way!  Danny in CA sent me one [$30!] and I got the rear brake set up and working...
Got the rear tail installed as well as the rear cover and tailight. Eric - now you can see the color of the body work!  Candy Gold...
Sent Triples forum member Don in FL my gauges, he does a phenomenal job!
Doesnt seem like much progress, seems like so much time is wasted searching, ordering and waiting for parts that are needed.
Basketcase bikes are a b!tch!
« Reply #1230 on: August 04, 2017, 05:39:18 PM »
 Luckily you got other nice stuff to ride so you can take as much time as you need but am sure the hunting for stuff does get to be a drag a little. Be well worth it when you finally get her done though.
« Reply #1231 on: August 04, 2017, 06:14:32 PM »
Learned that a long time ago - must have a rider while working on a project bike!
I dont mind the hunting for parts, its part of the challenge, I hate the waiting for the orders.  And boy, H2 parts are rare and pricey!
I need a special bolt for the R footpeg, it's $18!
http://www.ebay.com/itm/Kawasaki-H1-500-Change-Pedal-Bolt-H2-750-/172473086169?hash=item28283270d9:g:BScAAOSwEzxYbVhx&vxp=mtr
Luckily I had the L one, that one is $40!! Just for 1 bolt.
« Reply #1232 on: August 05, 2017, 04:38:34 AM »
 Makes doing a Sandcast look cheap !!  ;D  Wonder what this 1975 Kawasaki 750 might be, parts maybe ? Old add but maybe worth a call for you on your hunt.  https://southbend.craigslist.org/mpo/d/7-part-bikes-and-lots-of/6186233969.html
« Last Edit: August 05, 2017, 04:40:41 AM by ekpent »
« Reply #1233 on: August 05, 2017, 06:27:07 AM »
Thanks, text sent!
EDIT:  she replied, the 750 in the ad was sold.
« Last Edit: August 06, 2017, 12:46:37 PM by Stev-o »
« Reply #1234 on: August 12, 2017, 01:57:17 PM »
Time for an update.
I got my "Big Bang" bike back together after the catastrophic engine failure [3" hole in the case] so now I can concentrate on the H2.
Here's the '74 CB, now punched out to 836cc....
Back to the H2. Got the chain installed, all 120 links! it is long compared to the CB. Also installed the chainguard, it came to me powdercoated and looks good.
Took special precaution on mounting that front sprocket after reading a warning thread about how they like to come loose!
RED loctite!! I do not want a chain through the case of this bike, these engines are hard to find.
Disassembled the front caliper, thoroughly  cleaned and installed a new seal.  It cleaned up rather nice no I left the original paint.  Installed the hard pipe and lower hose, ordered a custom length upper hose from Slingshot.
[/url]H2 30
Installed the master cylinder, R control and throttle cable. I had Don on the Triples forum restore the controls when he did the gauges, his work is impeccable!
Buttoned up the birds nest in the bucket and installed the headlight, here is how she currently sits....
Have a list of parts that I need to order, so it's hurry up and wait...
« Reply #1235 on: August 12, 2017, 02:07:05 PM »
 That's quite a swirly hardline on that front brake. Really staring to look like a motorcycle.  What kind of pistons went into the Honda Steve, hopefully a little bump in compression maybe ?  Is it running well and pulling noticeably harder than a stocker.  In that stock trim it is lurching as a 'sleeper'.
« Reply #1236 on: August 12, 2017, 02:33:14 PM »
Hey Eric...yes some engineering went into that front brake hard pipe on the H2, that is the original part, I just polished it up.
I scratched my head for a minute figuring out how to install it, are basket case bikes fun?!! The ultimate puzzle.
The Big Bang K4 now has Wiseco 836cc forged pistons with 10.25:1 compression. I've put 200 test miles on it, it is running really good.
I am not pushing it yet, keeping the R's under 6000 for at least a couple hundred more miles...
Offline 02z06dave
« Reply #1237 on: August 12, 2017, 03:22:04 PM »
You're coming along nicely on this. Nice job
« Reply #1238 on: August 12, 2017, 03:59:24 PM »
Thanks Dave.   I'm staying committed on it now, want to get it on the road by Oct 1st.
« Reply #1239 on: August 16, 2017, 03:58:14 PM »
Update and a couple questions for you H2 experts:
Got the left side on the motor buttoned up...
Got the R footrest installed, but seems wrong, too far forward.
I actually sat on the bike for the first time today! [and made ring ding ding sounds!]
Have another footrest and the pin is welded, will try it.
Got most of the wiring connected.  Just received my Motobatt AGM battery [no acid spills!] and popped it in.  Does the fuse holder stay in the battery box strap?
What else goes on that strap on the right side?
I know ground from battery goes to frame, but where? [I dont have that cable].
These questions are also being asked on the Triples forum, but those guys are not always so responsive. And I've searched for project threads but they dont have them as specific as some of the ones that we have here for our Hondas.
Know it: this is THE best forum!
Quick link to wiring diagram:
http://3cyl.com/mraxl/wiring/H2Bwir.JPG
And what, if anything, goes in this little compartment directly behind the battery?  Tool holder is in the tail, right?
Thanks!
EDIT:   Triples forum Member Jim responded to my thread over there so I have a couple of the answers. If you'd like, you can guess on the answers for the following:
1.  What is the right holder for on the battery hold down strap?
2.  What goes in the triangular recess directly behind the battery.   Hint: Not a burrito!
« Last Edit: August 16, 2017, 04:12:20 PM by Stev-o »
« Reply #1240 on: August 16, 2017, 10:06:49 PM »
 I give but lets see if we have a Kaw Guru among us. Does your 500 have any of that stuff ?  If I may offer a suggestion it would be to go out and buy a perfect unmolested stock 750 so you can look it over while you put this one together  ;D ;D
« Last Edit: August 16, 2017, 10:12:44 PM by ekpent »
« Reply #1241 on: August 17, 2017, 06:39:52 AM »
Makes me feel good you dont know either!  My 500 does not have either of these, and that reminds me, it needs the proper battery holder as it did not come with one.
« Reply #1242 on: August 17, 2017, 06:58:12 AM »
 Did an owners manual go in the compartment there and used for other documents ??  Drug stash??  ;) I'll have to keep thinking on it and I promise I won't google !
« Last Edit: August 17, 2017, 06:59:58 AM by ekpent »
« Reply #1243 on: August 17, 2017, 06:59:59 AM »
No, doc holder is on the underside of the seat.
Offline KayOne
« Reply #1244 on: August 17, 2017, 08:48:09 AM »
 Chain oiler tank fits there on my 1973 H2A.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
« Reply #1245 on: August 17, 2017, 02:07:41 PM »
Bingo!  it was eliminated on the H2B, but they did not change the design [or my basket case came with an H2A battery box?!]  Got a pic of your bike?
BTW - the holder on the battery strap is for the battery overflow hose which I do not have [AGM]
Offline KayOne
« Reply #1246 on: August 17, 2017, 05:59:15 PM »
Hi Steve. I don't have any glamour shots of my bike so this pic will have to do.
The ground wire goes from the negative terminal of the battery, along the right side of the ignition box and fastens to the outer bolt as shown in the pic. The coils are grounded to the frame at the bracket attachments and the engine on the H2/H2A through the motor mounts. Not sure how the H2C engine is grounded as it has rubber mounts. Your battery box is correct for your bike as indicated by the bolt halfway down rearward side of the triangle.
These bikes are so much different from anything else I have ridden!
« Last Edit: August 17, 2017, 06:01:26 PM by KayOne »
CB750 K1 restored
1973 H2a, Restored
CB750K1 (sold)
1976 KZ900 (sold)
« Reply #1247 on: August 17, 2017, 06:09:43 PM »
Great lookin bike, Kay, thanks for posting.   Looks to be in excellent restored condition.  How long have you had it?
Thanks for the info, that is helpful.  My bike is an H2B, no rubber motor mounts.
Offline KayOne
« Reply #1248 on: August 17, 2017, 06:42:35 PM »
Thanks for the compliments😀 I found the bike in an old chicken coop along with 2 H1D'S and parts and pieces of 3 early H1/H1A's. $1200 Canadian and I was on my way.
The bike was rough and missing a lot of parts. I sourced a lot of parts by trading my stash of early H1 parts. Took a couple of years to collect everything, including a fair amount of reproduction parts. Most of the chrome parts are original and rechromed.
The bike had been dropped numerous time so I had to straighten the brake pedal mount, the exhaust mounts and the brake pedal itself. The PO welded the kick start to the shaft!  Since the kick starters are unobtainium for these bikes I had to carefully grind the weld off to save the assembly.
Sorry, don't want to highjack your thread Steve. You are going to find this bike very different from your H1! Torque everywhere. I couldn't stand the stock carbs and replaced them with Mikuni TM34's. Still tuning but way more power and drivability.
CB750 K1 restored
1973 H2a, Restored
CB750K1 (sold)
1976 KZ900 (sold)
« Reply #1249 on: August 17, 2017, 07:19:24 PM »
 Love that purple and great job on the resto. Sounds like you put a ton of time,effort and I am sure dollars into it but what a great story and find for you. Bet you two will be talking some more as Steve keeps bolting on pieces.
