Author Topic: Cheap way to clean foggy plastic headlights  (Read 2867 times)
Offline 74cb750
« on: April 17, 2013, 03:56:31 PM »
Hi All,
 a friend of mine showed me this:
Just take a rag, soak it with brake cleaner and whip on the headlight plastic.
My lights came out better than when I used the expensive sandpaper and buffer kit.
huh, I guess when you're a mechanic for 35 years you learn a few things.
peace,
michel
anyone else try this?
I know some fairings have the cheap clear plastic if front of the headlight. Wonder if it does any damage.
Laugh at least once a day.
Life  $ucks, then you die.
Offline Gordon
  • 750K1, 550K2
Re: Cheap way to clean foggy plastic headlights
« Reply #1 on: April 17, 2013, 06:03:47 PM »
I've always used automotive finish polish.  It does basically the same thing as wet-sanding but removes less material and leaves a very smooth finish.  I've used it on countless plastic car headlight covers and a few clouded motorcycle fairings and helmet visors with very good results.  I've never tried brake cleaner, but if it works by dissolving the top layer of plastic it might also be weakening the remaining plastic, too.
Offline brooze72
« Reply #2 on: April 17, 2013, 07:26:46 PM »
Yea I would worry about what it does to the plastic.  You know what that stuff does to paint..!
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline Magpie
« Reply #3 on: April 17, 2013, 10:27:42 PM »
I used Blue Magic metal polish and a Mother's mini Powerball in my drill on a Jeep Grand Cherokee's headlights and they came out fine. I think you may have to careful about generating too much heat though. Cliff.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #4 on: April 17, 2013, 11:24:10 PM »
Got advice on this today by coincidence from a customer of mine who is a mirror manufacturer. He was looking at my bike (Triumph Sprint) parked in his shop yard and I have a plastic headlight guard over the glass..he said - to clean this, use SILVO..not BRASSO......SILVO. Industry trick so he reckons for cleaning plastic without scratching..
Offline demon78
  • After work to the "Wets"
« Reply #5 on: April 18, 2013, 03:30:19 AM »
Yeah less abrasive in Silvo and finer grit, when it was time to polish our brass, start off with Brasso and final with Silvo.
Bill the demon.
Offline nccb
  • 1974 CB750 Four
« Reply #6 on: April 18, 2013, 05:14:22 PM »
baking powder and toothpaste
« Reply #7 on: April 18, 2013, 06:16:35 PM »
I truly dislike plastic headlights. Cheap crap in my opinion. Great tip!  Thanks
