Author Topic: Ignition system  (Read 1420 times)
Sal
Ignition system
« on: July 26, 2006, 11:48:45 AM »
First off let me say that this site is awesome. I bought a 76 550F for my girlfriend recently and I'm going through it (it's been sitting for about 10 yrs). The bike is cherry but the fuel system needs to be thoroughly gone through and the info I've picked up off this site has been invaluable. Anybody out there have any thoughts on the "ideal" ignition set-up on this type of scooter ie; coils,wires, plugs, points vs electronic etc.  Gonna leave it as stock as possible with the exception of a foam air filter.Any input would be greatly appreciated.
Offline StevieMac
Re: Ignition system
« Reply #1 on: July 26, 2006, 12:25:28 PM »
Personally I find that points work just fine.  I really can't find a good reason to spend the money on electronic ignition when really there is nothing wrong with the points.  Sure they require some maintanance etc but to me that's not a big deal.
72 CB500 Cafe
78 CB750 Chopper
Gallery: http://www.sohc4.us/gallery/v/members/personal/StevieMac/
Offline STLrocker
  • whiskey bent and hell bound
Re: Ignition system
« Reply #2 on: July 26, 2006, 12:30:37 PM »
your best bet would probably be to go with the dyna electronic ignition. it is the most readily available, reasonably priced, and once you set it up, it dosent have to be adjusted or messed with at all. you will get accurate timing, strong spark, and also no point float at high RPM.
the points work fine, but you need to replace them and the condenser ocassionally and make adjustments to the points and timing in between. much more maintenance.
thre are other electronic ignitions available, both new and used. i have a martek. it works great. there is also boyer. i just recomend dyna cause its easiest to get and performs as well as the others
if your coils are working fine, you can use them. i have stock coils on one bike and dynas on the other. i really cant tell a difference. if yor coils are bad, you could get the dyna, or accell 3 ohm to go with the electronic ignition. if you keep the points you will need 5 ohm, which you can also get from dyna and possible accell.
as for wires, if you keep your old coils, you may be able to use the old wires if they are i good condition. if not, or if you get different coils, you can get wires from the coil manufacurer, or make you own. i make mine from a universal v-8 kit from the auto parts store. it comes with 8 wires and lots of boots and crimp on terminals. you cut the wires to length and crimp on the ends you need.
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
Re: Ignition system
« Reply #3 on: July 26, 2006, 01:59:21 PM »
I am using the basic Dyna S on my 500, one of the
least expensive units they make (about $150 I think? shop around.)
It was almost dissapointingly easy to install. I had set
aside an entire afternoon and a chilled 6 pack to
put it on and it took all of about 20 minutes.
Works flawlessly with original coils.
Bikes parked out front mean good chicken-fried steak inside.
Re: Ignition system
« Reply #4 on: July 26, 2006, 02:22:43 PM »
Since 1975, I've frequently toyed with the idea of electronic ignition on my SOHC4.  I've always been discouraged by the unnecessary expense of the conversion.  I can dress and adjust points and do timing in about 5-15 minutes during the tuneup.   If that much of your time is worth the $125 to $150, then go electronic.  I have 30,000 miles on one set of points. That's about 10 dressings.  The condensers can go bad with long periods of disuse and extreme age.  I bought two spare plates with points and condensers from Honda 10 years ago in anticipation of replacing the points when they failed to work right anymore.  They are still in the box out in the garage.  You must keep the point cam well lubed to make points last this long, though.
High RPM and point float can be a real problem... If you insist on reving past 10,000 RPM.  What red line are you ignoring?
Even so, simply double springing the points will get you up near 13,000, I believe.
Still, the salesmen have had years of practice at convincing customers to shell out the bucks for electronic ignition "upgrades".  I trust you understand their motivation at keeping the customers "happy".  Does the phrase"selling ice cubes to Eskimos" ring a bell?
The coils are not bullet proof.  Really, you can do serious damage with even a small handgun.  Also, avoid any that have had any encounters with hatchet like implements.  Mostly, if they look good on the outside, they will most likely still be sparking when we are all resting in coffins.
Alas, the weak point is the wires, themselves.  Or, rather, the insulation of the ignition wires.  Age and heat are not kind to them.  Brittleness and cracking is a very very bad thing, as that lets the spark out before the plugs get a chance to do their thing.
The very best argument for replacing the coils is because the ignition leads are molded into them and they have cracked.
Don't let the 750 guys talk you into 3 ohm coils for city driving.  The 550s have smaller batteries and 60 watts less alternator output.  And, neither charges the battery at idle speeds.  Low speed operation will run down your battery quicker with extra loads.  When the battery dies, so does the bike, usually at the stop light or stop sign, in traffic, who then proceed to drive around you at high rates of speed and as close as they can to scare you.  (sometimes shouting, in the process.)  Picture your GF in that situation.  And, you explaining to her that she has to keep the RPM up for future avoidance of a repeat occurrence.  And, that she can take out the headlight fuse to get the bike kick started again.  I'm fairly confident that whatever name given the bike beforehand.  After such an event, it will either have a new, less endearing name, or a new expletive appended to its present one.
If you decide to keep the points, ensure their their reliability in the wet by making a neoprene gasket for the points cover.  The stock, cork one is laughably good for only one compression cycle for a "sort of" seal.  Make one from hardware store neoprene, and reuse it for... I don't know... I've not worn one out yet. 20 years a still going and going andgoing.
Offline StevieMac
Re: Ignition system
« Reply #5 on: July 26, 2006, 02:29:29 PM »
As usual I learned a lot from your post TwoTired.
Where in the hardware store would one find neoprene to make a gasket?
72 CB500 Cafe
78 CB750 Chopper
Re: Ignition system
« Reply #6 on: July 26, 2006, 02:41:07 PM »
At my local OSH, it's in the industrial section under the table where they cut roll goods like screens and rubber mats, etc.
