Author Topic: Starter Motor on Honda CB 500 Four  (Read 2235 times)
Offline Nagoshak
« on: April 21, 2013, 11:54:20 AM »
I've just filled it with oil  for the first time since the rebuild but i need to circulate the oil to prime it (just running the starter motor) also I won't be starting it yet. So how do i hot wire the starter motor to prime the engine.
Offline goldarrow
  • one day, i'll be an
Re: Starter Motor on Honda CB 500 Four
« Reply #1 on: April 21, 2013, 11:58:00 AM »
You can take just keep kicking the motor using kick starter.  Take spark plugs out and you can do it by hand.
CB550 K0
Offline iron_worker
« Reply #2 on: April 22, 2013, 09:56:48 AM »
It's pretty easy to wire up the solenoid to work.
The large gauge wire coming from the starter goes to the solenoid. Should just have a ring terminal. The other side of the solenoid should have another ring terminal which attached your main + battery cable. Obviously that needs to be hooked up to the battery +.
The starter solenoid then has two small gauge wires coming out of it. These two wires power up the magnet inside which draws closed the terminals between the two + large gauge wires. I believe you just hook up one of the small gauge wires to battery + and one to ground. Use some sort of jumper that is easily removed because this will be your makeshirt starter "switch".
Then all you'll need is to hook up your large gauge ground wire between your engine and battery negative.
OR just kick it as was said. lol
IW
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: April 22, 2013, 10:56:34 AM »
Or stick a spanner between the two nuts on the solenoid. :)
