Author Topic: Are these aluminum or Ti ?  (Read 2292 times)
Offline hrcscott
« on: April 24, 2013, 02:53:34 PM »
hi there...
these are out of a donor motor and was wondering if the retainers would be worth using in my 550 racebike?
Not sure if they are aluminum or Ti? anyway to tell? they're not magnetic..would have to have them machined down to fit my Dynoman springs so I don't know if it's worth the trouble?..the outer spring ledge is about 1mm wider than the stock retainers..
Each one is 3g lighter than stock but I had read recently on a thread here ( can't find it now) that old school aluminum retainers aren't reliable?
Also, anyone recoginize the springs ? some sort of progressive wound ones..shorter than the Dynoman springs..
thanks in advance for the help,
Scott
82 CB900F / CB550 race / 83 RS125W / 92 RS125 / 81 XR80  my Daughters !!
Offline Tintop
Re: Are these aluminum or Ti ?
« Reply #1 on: April 24, 2013, 04:48:28 PM »
There's a post on the VRRA forum Scott for aluminum NOS retainers (CB750).  Enough that you could probably put in a new set for each event. ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #2 on: April 24, 2013, 10:00:49 PM »
They dont look like aluminum.
Offline BLUE71TURBO
« Reply #3 on: April 24, 2013, 10:29:48 PM »
 The easiest way to tell the difference between aluminum and titanium is with a grinder. Aluminum will not spark, titanium will spark like hell's bells !   :o   You can use a file on the retainer, as aluminum is softer and titanium is way harder.  Aluminum retainers are real light, Titanium retainers are heavier.   ;)
« Reply #4 on: April 24, 2013, 11:54:52 PM »
Thats what i was thinking, you can usually tell alloy just by looking at them.  For what its worth, i have some alloy retainers right next to me and they are lighter colored than the ones pictured, just what i would expect alloy to look like....
Offline trueblue
« Reply #5 on: April 25, 2013, 01:11:02 AM »
I agree they don't look like aluminium, I would try a file on them, if it files like butter then it is not titanium ;)
1979 CB650Z
Offline Jim F
  • go baby go
« Reply #6 on: April 25, 2013, 03:54:47 AM »
They look like ti
If you grind a small area it will throw off a white spark
If titanium
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #7 on: April 25, 2013, 04:54:34 AM »
Aluminum is generally anodized
Offline Bill/BentON Racing
    • BentON Racing
« Reply #8 on: April 25, 2013, 05:49:35 AM »
Send me those,i'll send some we KNOW are aluminum!!!  Two sets to one!!! ;) ;D They don't look alum. Bill
BentON Racing Website
BentON Racing Facebook
« Reply #9 on: April 25, 2013, 07:47:41 AM »
Hey Scott they look plastic to me, toss em. I have some really trick lead retainers here I'll send you. Yea that'll help........................................me!  ::)
Offline Jim F
  • go baby go
« Reply #10 on: April 25, 2013, 08:02:56 AM »
you need to keep those................
« Reply #11 on: April 25, 2013, 08:24:35 AM »
Sorry Jim my sarcasm will not go unnoticed on Scott.
We race together in the same class, he won't be tossing them... especially because I say so!
Offline hrcscott
« Reply #12 on: April 25, 2013, 10:53:25 AM »
To all those who replied ( except Mr.Waller ;)...thanks for your input...extremely helpful as usual !!
hey Jim...I'm thinking you're serious?..are they worth having turned down to run do you think? they are matched size wise to those springs in the pics (which I have no idea what they are) so I didn't know if I should keep them as a set for future use or turn them down and use them now?
And because you showed up in my class I now have to spend Mega $$$ to try to keep up with the Blue Rocket..I was doing just fine till you ruined the party  :'( And yes your word is still Gospel to me and my build  ::)
« Last Edit: April 25, 2013, 11:26:24 AM by hrcscott »
Offline Jim F
  • go baby go
« Reply #13 on: April 25, 2013, 01:59:23 PM »
It just depends on what they fit and what your going to have to do to make
them work with your application................Ti is tough to work sometimes if your not familiar with
machining the stuff
I made some Ti hangers for my turbo build and went threw a couple of very expensive end mills
good luck
Offline hrcscott
« Reply #14 on: April 25, 2013, 02:28:06 PM »
hey Jim..
would have to turn off about 1 mil from the edge that sits in the outer spring to fit the Dynoman springs..and probably 1 mil off the top edge to bring it to the stock size..
Scott
« Reply #15 on: April 25, 2013, 03:53:34 PM »
Yes i agree, most of the alloy ones i have seen are anodized but i have a set on a head {that troublesome one i talked to you about} and they are definitely not anodized... ;)
« Reply #16 on: April 25, 2013, 07:07:09 PM »
Test the pressure on the unknown springs and see how they compare to the others. If you don't have a proper spring tester, put a scale on the table of a drill press, and measure how many pounds it takes for each spring to compress a certain distance.
