Author Topic: "better" brake & clutch leavers on OEM controls?  (Read 1855 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: April 26, 2013, 11:34:45 PM »
is there any way to swap out the stock 750K levers for some with a bend?
that is, swap these:
for something like these:
while keeping the OEM controls?
Offline LesterPiglet
  • 1977 CB550F2
Re: "better" brake & clutch leavers on OEM controls?
« Reply #1 on: April 27, 2013, 01:31:09 AM »
Yes. I have doglegs on mine, I have small hands.
« Last Edit: April 27, 2013, 01:36:59 AM by LesterPiglet »
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: April 27, 2013, 01:46:04 AM »
I have them on one of my 750's but cannot remember where they came from or what manufacturer.  They do work well.  ...Larry
« Reply #3 on: April 27, 2013, 02:03:39 AM »
you sound like my wife lester,,she has smalll hands aswell,she makes my lever look big,make sure youll get the full action from them though,,this can be where some have had clutch adjustment issues?not getting full travel etc?
« Last Edit: April 27, 2013, 02:06:06 AM by dave500 »
  • 1977 CB550F2
« Reply #4 on: April 27, 2013, 02:58:04 AM »
I've used them for years without a problem.
Hmmm, all the women I've been with must have small hands as well.  :P
Offline trueblue
« Reply #5 on: April 27, 2013, 03:57:26 AM »
Why? ??? Do they all wear small gloves? ::)
1979 CB650Z
Offline grumpy
« Reply #6 on: April 27, 2013, 08:02:35 AM »
wow, cool.
no problems with fitment on the brake reservoir?
« Reply #7 on: April 27, 2013, 08:40:32 AM »
AAAAAAAAAHAHHAHAHAHAHAHHAHHAA.
thanks for that, Dave   ;D
Offline bjbuchanan
« Reply #8 on: April 27, 2013, 08:46:53 AM »
I got doglegs for my stock controls from dime city. If you shop around you can usually beat their prices for this stuff by a dollar or two. Convenience and me buying other stuff was why I went with them. They cost like 12$ and fit right up. I used plastidip on the ends to get that rubberized end to to lever and it works/looks good.
Dave you spoke what hit everybods mind
Offline mronegear
  • Honda CB 550 F 1976
« Reply #9 on: April 27, 2013, 12:08:49 PM »
Thanx for that input Dave!
I was wondering about my clutch lately and thought about a replacement, but i think in my case its because of that bent lever like in the picture. The PO put them on, i don't know why...
So before i mess with my clutch i will switch back to the original levers, that's for sure  ;D
And i think, that will fix my clutch issues  ;D ;D
cheers!
Offline bjbuchanan
« Reply #10 on: April 27, 2013, 09:39:57 PM »
Go through the clutch adjustment procedure and then adjust the clutch lever play just a little tighter with the dog leg lever. Get it close using the bottom stuff and fine tune up top at the lever so that you have like a 1/4" of free wiggle at the end ball of the lever for the dog leg style. You will have a closer lever with a clutch that fully disengages. Lube that cable up while you are at it huh
